Sim
(Sim)
1
Hello!
I’ve 5 switch (1bit boolean).
Is it possibile to create a “unique item” where I can select one of them?
Example:
Select Option A | B | C | D | E
Instead of:
Select Option A
Select Option B
Select Option C
Select Option D
Select Option E
Regards
Sim
Dim
(Angelos)
2
First of all: The Selection (not Select) is relevant for sitemaps (not items)
Post your item configs and the sitemap entries
What exactly do you want to achieve?
Sim
(Sim)
3
Hello Dim,
thank you for reply.
This is the case:
Switch ModeAuto "Mode Auto" (gCond) { knx = "<11/0/21" }
Switch ModeHeat "Mode Heat" (gCond) { knx = "<11/0/22" }
Switch ModeDry "Mode Dry" (gCond) { knx = "<11/0/23" }
Switch ModeFan "Mode Fan" (gCond) { knx = "<11/0/24" }
Switch ModeCool "Mode Cool" (gCond) { knx = "<11/0/25" }
Switch FanAuto "Fan Auto" (gCond) { knx = "<11/0/31" }
Switch FanLow "Fan Low" (gCond) { knx = "<11/0/32" }
Switch FanMid1 "Fan Mid1" (gCond) { knx = "<11/0/33" }
Switch FanMid2 "Fan Mid2" (gCond) { knx = "<11/0/34" }
Switch FanHight "Fan Hight" (gCond) { knx = "<11/0/35" }
Switch VaneHoriz "Vane Horiz" (gCond) { knx = "<11/0/41" }
Switch VanePos1 "Vane Pos1" (gCond) { knx = "<11/0/42" }
Switch VanePos2 "Vane Pos2" (gCond) { knx = "<11/0/43" }
Switch VanePos3 "Vane Pos3" (gCond) { knx = "<11/0/44" }
Switch VaneVertic "Vane Vertical" (gCond) { knx = "<11/0/45" }
Switch VaneSwing "Vane Swing" (gCond) { knx = "<11/0/46" }
Switch VaneAuto "Vane Auto " (gCond) { knx = "<11/0/47" }
My idea is create 3 “element” (switch or other) with the options instead of all.
At each change, the old setting of the group (Mode/Fan/Vane) changes state
I was thinking of something like that:
Switch item=Shutters label="Close" mappings=[0="0%", 15="25", 30="50", 45="75", 75="90", 100="100"]
but with multiple switch.
Best regards
Sim
Dim
(Angelos)
4
I still don’t get what you want to achieve…
Did you look into Groups? Maybe they provide the functionality that you are looking for
