I would like to open my rollershutter 30 min before sunrise. I can see that I can offset the event, but I ALSO want the possibility of triggering something to exact sunrise, so I would like to have event channels with different offsets.
What is the way to go there? I don’t see a custom field for the channel name in the docs. Should/Can I define another thing astro:sun:home_30_45 for channel offsets like 30 min before sunrise and 45 minutes after sunset?
import org.joda.time.DateTime
var Timer LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_Timer = null
var Timer LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_Timer = null
rule "LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_Rule"
Item LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_MinHour received update or
Item LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_MinMinute received update or
Item LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_Offset received update or
Item LE_CivilDawn_Time received update
var DateTime civilDawnTime = (new DateTime((LE_CivilDawn_Time.state as DateTimeType).calendar.timeInMillis)).plusMinutes((LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_Offset.state as DecimalType).intValue)
var DateTime minRiseTime = now.withTimeAtStartOfDay().plusHours((LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_MinHour.state as DecimalType).intValue).plusMinutes((LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_MinMinute.state as DecimalType).intValue)
var DateTime riseTime = null;
if (minRiseTime.isAfter(civilDawnTime)) {
riseTime = minRiseTime;
} else {
riseTime = civilDawnTime;
if (LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_Timer != null)
LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_Timer.cancel();
logInfo("Rollershutter","Timer for UP: "+riseTime)
postUpdate(LE_Groundfloor_Livingroom_Gardendoor_Shutter_RiseTime,new DateTimeType(riseTime.toCalendar(null)))
if (now.isBefore(riseTime))
LE_Groundfloor_Livingroom_Gardendoor_Shutter_Rise_Timer = createTimer(riseTime) [|
LE_Groundfloor_Livingroom_Gardendoor_Shutter.sendCommand(UP)
rule "LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_Rule"
Item LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_MinHour received update or
Item LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_MinMinute received update or
Item LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_Offset received update or
Item LE_CivilDusk_Time received update
var DateTime civilDuskTime = new DateTime((LE_CivilDusk_Time.state as DateTimeType).calendar.timeInMillis).plusMinutes((LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_Offset.state as DecimalType).intValue)
var DateTime minSetTime = now.withTimeAtStartOfDay().plusHours((LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_MinHour.state as DecimalType).intValue).plusMinutes((LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_MinMinute.state as DecimalType).intValue)
var DateTime setTime = null;
if (minSetTime.isAfter(civilDuskTime)) {
setTime = minSetTime;
} else {
setTime = civilDuskTime;
if (LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_Timer != null)
LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_Timer.cancel();
logInfo("Rollershutter","Timer for DOWN: "+setTime)
postUpdate(LE_Groundfloor_Livingroom_Gardendoor_Shutter_SetTime,new DateTimeType(setTime.toCalendar(null)))
if (now.isBefore(setTime))
LE_Groundfloor_Livingroom_Gardendoor_Shutter_Set_Timer = createTimer(setTime) [|
if (LE_Groundfloor_Livingroom_Gardendoor_Lock.state == CLOSED) {
LE_Groundfloor_Livingroom_Gardendoor_Shutter.sendCommand(DOWN)
rule "LE_Groundfloor_Livingroom_Gardendoor_Lock_Close_Rule"
Item LE_Groundfloor_Livingroom_Gardendoor_Lock received update CLOSED
var DateTime civilDawnTime = new DateTime((LE_CivilDawn_Time.state as DateTimeType).calendar.timeInMillis)
if( ( now.isAfter(civilDuskTime) && now.isAfter(minSetTime) ) || ( now.isBefore(civilDawnTime) && now.isBefore(minRiseTime) ) )
sendCommand(LE_Groundfloor_Livingroom_Gardendoor_Shutter,DOWN)
Opens and closes my rollershutters at dusk and dawn, with earliest times from the sitemap, and closes them if the door is locked during the closed period. (Opening is done in the controller, for escape route security purposes.) According to the log, it should work.
