Hi
I have now added mysql persistence.
Is there any reason to keep rrd4j persistence?
/mike
Hi
/mike
Ah no
i user mySQL for all measures like temperature, humidity and mapdb for all switches where only the latest state is relevant
Thomas
A couple possible reasons to keep rrd4j…
@tnemrap
You can use mySQL for everything, but i don’t care about the state a switch has 2 years ago, but if this is relevant then you can use mysql.
@steve1
To first topic - I am generating my charts with mySQL persistance
To second - Yes that is true and should be kept in mind
Persistance should be selectetd on the requirements.
Thomas
Did you write your own chart generation code?
No, but it works with those lines
Chart item=gScOs_WeatherTemperatures service="mysql" period=4h refresh=60000 visibility=[SlVt_ChartIntervall==2]
Thomas
Is this a old release issue? I use myql and generate charts.
Text item=Today_Propane_Used icon="propane" {
Frame {
Switch item=Today_Period label="Chart Period" mappings=[1="Week",2="Month", 3="Year"]
Chart item=Today_Propane_Used service="mysql" period=W refresh=10000 visibility=[Today_Period==1]
Chart item=Today_Propane_Used service="mysql" period=M refresh=10000 visibility=[Today_Period==2]
Chart item=Today_Propane_Used service="mysql" period=Y refresh=10000 visibility=[Today_Period==3]
Apparently. The wiki appears to be out of date.
For the moment, only the server-side chart creation as PNG through rrd4j is implemented. More to come soon!
