Hey everyone
Is it possible to have 2 sitemap files? One to use and one for testing an addition to a sitemap? Essentially a copy of the original so I can swap between the two to see if what I have added works or not?
Hey everyone
Sure. You can have as much sitemaps as you want.
Call them directly via
http://<openhab_ip>:8080/basicui/app?sitemap=sitemapname
Yes absolutely
You can swap by changing the default sitemap in the paperUI configuration/Services/UI
Thanks gentlemen. Will have a tinker later!
That’s what I was looking for!!
Is it possible to use them together?
I’m thinking: a sitemap for the parrents and one for the children.
Is that possible?
Can multiple sitemaps use the same items file?
Yes.
