Hey guys,
Need a little help please!
So… I have a video matrix system that requires two button presses to get to the desired function.
Eg. If i wanted Input 1 on Output 4 then I would need to press ‘Input 1’ on the remote and then ‘Output 4’.
I have these learnt these IR commands on a Broadlink device and connected via WebHooks in IFTTT, then in my items file have the respective WebHook linked as so…
Switch Input1 "Input 1" ["Switchable"] { http=">[*:POST:https://maker.ifttt.com/trigger/Input1/with/key/xxxxxxxxxx:default]" }
Switch Output4 "Output 4" ["Switchable"] { http=">[*:POST:https://maker.ifttt.com/trigger/Output4/with/key/xxxxxxxxxx:default]" }
I wanted to have 1 switch that would send two HTTP Post commands to IFTTT so i could press eg. “TV 4 Input1” and it would send a command to IFTTT as Input1 and Output4.
I’m sure this is simple and im just too inexperienced! Any help would be greatly appreciated
Cheers!
