Multiple xiaomi gateways - but only one gateway is online at a time
i have been using 3 xiaomi gateways successfully for a long time. since about 4 weeks there are always two gateways offline, only 1 gateway is working at the same time. 2 bridges are always offline.
Individually I can run all 3 gateways, but not together (if I set 2 gateways to disable in the paper ui).
what i did once again is an openhab update from version 2.5.1 to 2.5.4
does anyone have an idea what this could be?
Are you sure you updated to 2.5.4 or 2.5.5? Apparently the binding in 2.5.5 is broken according to this posting.
i have updated to version 2.5.4. is this problem fixed with 2.5.5?
It looked to me that it broke in 2.5.5 according to the link earlier. I do not use that binding.
It’s fixed in 2.5.5. See:
And:
thanks for your help … update from 2.5.4 to 2.5.5 has solved this problem. Now, all 3 gateways works fine.
