I’ve had 2 Multisensors for several months now working without any issues. Bought another one the other week. Had some issues getting it set-up but I guess that’s nothing out of the ordinary with Z-Wave devices. Eventually got OH2 to recognise it and initialise it. Seems to work alright except that it doesn’t detect motion. I tried everything I could think of - updated openhabian, upgraded the firmware on the sensor, downgraded the firmware, excluded it, re-included it etc. The furthest I got is that the motion seemed to turn on and off randomly but eventually got to a point where it’s just staying on.
Thought that there was something wrong with the sensor so I bought a new one to test. Inclusion went alright. The motion detection seemed to work at first but then realised that when the motions turns off, it turns on again after about 2 seconds.
The sensor is battery powered and changed all the configuration parameters to match the ones of my working sensor. Firmware is V1.11. My working ones are on V1.7.
Anybody got any ideas? I’m starting to feel that it might be an issue with my OH or with the new version?
Quick update. One thing I hadn’t tried yet was set it up whilst plugged into the USB so I tried it and the sensor worked immediately as expected including the motion. I reinitialised the device whilst battery powered and it’s back to switching the motion back on 2 secs after it turns off.
The association group 1 is set up the same as my other sensors. It is reporting to the controller, temperature, humidity etc all work fine. It’s just the motion that turns itself back on 2 seconds after turning off
Yes, when the sensor is powered by USB it works as expected.
I contacted Aeotec last night, they suggested that the problem might be due to rechargeable batteries, as their slightly higher voltage might cause these problems.
I just ordered some non-rechargeable ones as I only had rechargeable batteries. I’ll keep you updated.
If this is really causing the issue, it’ll be a massive disadvantage of these sensors, given how quickly the batteries run out and how difficult they are to get hold of!
