let me get my.openhab set up but until then, here is my startup…you can see im having trouble with my with some persistence items which I havent educated myself on just yet.
Launching the openHAB runtime…
osgi> 2016-11-25 21:36:58.007 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
2016-11-25 21:36:58.621 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-11-25 21:36:58.850 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-11-25 21:37:00.064 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-11-25 21:37:08.643 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'Orcas.sitemap’
2016-11-25 21:37:08.807 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist’
2016-11-25 21:37:08.817 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist’
2016-11-25 21:37:08.820 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist’
2016-11-25 21:37:08.822 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist’
2016-11-25 21:37:08.856 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'orcas.script’
2016-11-25 21:37:08.949 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'orcas.items’
2016-11-25 21:37:09.287 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-11-25 21:37:13.345 [INFO ] [.service.AbstractActiveService] - Sonos Refresh Service has been started
2016-11-25 21:37:13.633 [INFO ] [.b.sonos.internal.SonosBinding] - Querying the network for a predefined Sonos device with UDN uuid:RINCON_B8E9378FA3EC01400
2016-11-25 21:37:13.639 [INFO ] [.b.sonos.internal.SonosBinding] - Querying the network for a predefined Sonos device with UDN uuid:RINCON_B8E93733B23801400
2016-11-25 21:37:13.640 [INFO ] [.b.sonos.internal.SonosBinding] - Querying the network for a predefined Sonos device with UDN uuid:RINCON_B8E93733B27201400
2016-11-25 21:37:13.641 [INFO ] [.b.sonos.internal.SonosBinding] - Querying the network for any other Sonos device
2016-11-25 21:37:13.730 [INFO ] [o.harmonyhub.HarmonyHubGateway] - HarmonyHub gateway activated
2016-11-25 21:37:13.754 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-11-25 21:37:13.829 [INFO ] [o.o.b.w.i.common.WeatherConfig] - ProviderConfig[providerName=WUNDERGROUND,apiKey=xxxxxxxxxxx]
2016-11-25 21:37:13.829 [INFO ] [o.o.b.w.i.common.WeatherConfig] - LocationConfig[providerName=WUNDERGROUND,language=en,updateInterval=3,latitude=xxxxx,longitude=xxxxxx,woeid=,locationId=xxxxx,name=xxxxxx]
2016-11-25 21:37:13.860 [INFO ] [insteonplm.InsteonPLMActivator] - Insteon PLM binding has been started.
2016-11-25 21:37:13.874 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - poll interval set to 300000 per config file
2016-11-25 21:37:13.874 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - dead device timeout set to 3000s
2016-11-25 21:37:13.874 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - config: poll_interval -> 300000
2016-11-25 21:37:13.875 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - config: port_0 -> /hub2/xxxxx:xxxxxx@XXX.XXX.XXX.XXX:25105,poll_time=1000
2016-11-25 21:37:13.875 [INFO ] [.service.AbstractActiveService] - InsteonPLM has been started
2016-11-25 21:37:13.882 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - devices: 0 configured, 0 polling, msgs received: 0
2016-11-25 21:37:13.887 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - config: service.pid -> org.openhab.insteonplm
2016-11-25 21:37:13.931 [INFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-11-25 21:37:13.936 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-11-25 21:37:14.694 [INFO ] [.b.sonos.internal.SonosBinding] - Found a Sonos device (S3) with UDN uuid:RINCON_B8E93733B27201400
2016-11-25 21:37:14.709 [INFO ] [.b.sonos.internal.SonosBinding] - Found a Sonos device (S1) with UDN uuid:RINCON_B8E9378FA3EC01400
2016-11-25 21:37:14.775 [ERROR] [.myopenhab.internal.MyOHClient] - Socket.IO error: not authorized
2016-11-25 21:37:14.926 [INFO ] [.b.sonos.internal.SonosBinding] - Found a Sonos device (ZP90) with UDN uuid:RINCON_B8E93798A63C01400
2016-11-25 21:37:15.098 [INFO ] [.b.sonos.internal.SonosBinding] - Found a Sonos device (S3) with UDN uuid:RINCON_B8E93733B23801400
2016-11-25 21:37:16.845 [INFO ] [.o.b.w.i.s.WeatherJobScheduler] - Disabling weather locationId ‘orcas’, no binding available
2016-11-25 21:37:18.999 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'orcas.rules’
2016-11-25 21:38:00.115 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Persistence Demo
java.lang.RuntimeException: The name ‘Weather_Temperature’ cannot be resolved to an item or type.
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:67) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_111]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_111]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_111]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.8.0_111]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:545) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:327) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
2016-11-25 21:38:40.739 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - modem database has 12 entries!
2016-11-25 21:38:40.742 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 3A.E6.63 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x01] and responds to groups [0x01].
2016-11-25 21:38:40.744 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 35.4A.3F found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.746 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 3D.7F.91 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.748 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 39.84.53 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.750 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 35.4D.99 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.752 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 27.22.F9 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.763 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 37.B2.3E found in the modem database, but is not configured as an item and the modem responds to groups [0x01].
2016-11-25 21:38:40.765 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 3C.3F.6B found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x02,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.767 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 3C.41.7E found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.768 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 39.81.68 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:38:40.769 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - device 3B.A7.10 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F] and responds to groups [0x01].
2016-11-25 21:39:00.043 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Persistence Demo
