Finaly i think i got it working!!! The only thing that i couldnt figure out is the rule tha runs the tstat script every 5 min. It seems to be running but no changes to my items. i overcame the problem by creating a scheduled task with crontab.
Here are my config files for anyone interested using these scripts with openhab 2.3.
items file
// Honeywell Thermostat
Number IndHeat "Current Set Point [%.1f°C]" <temperature> (persist)
Number IndHoldStatus "Hold Status [MAP(thermostat2.map):%d]" <temperature> (persist)
Number IndHeaterStatus "Heat On/Off [MAP(thermostat.map):%d]" (persist)
Number IndTemp "Indoor Temp [%.1f°C]" <temperature> (persist)
Number SendTemp "[%.1f°C]" (persist)
Number IndHeatSet "Set Temp [%.1f°C]" <temperature> (persist)
String IndHeatRes "Resume Schedule" (persist) { autoupdate="false",exec=">[ON:python /etc/openhab2/scripts/therm.py -x] >[OFF:python /etc/openhab2/scripts/therm.py -x]" }
sitemap file
Text label="Thermostat" icon="thermostat" {
Frame {
Text item=IndHoldStatus
Text item=IndHeaterStatus icon="heating"
//Text item=IndFanStatus
Text item=IndTemp
Text item=IndHeat
Setpoint item=IndHeatSet minValue=16 maxValue=23 step=0.5
Switch item=IndHeatRes label="Resume Schedule" mappings=[ON="Resume"] icon="Date"
Rules
//Honeywell Thermostat
// Send selected temperature to MyTotalConnectComfort Portal
rule "IndHeatSet"
Item IndHeatSet received command
SendTemp.sendCommand(IndHeatSet.state)
// Set Heat Setpoint
rule "Send SetPoint to MyTotalConnectComfort Portal"
Item SendTemp received command
executeCommandLine(" /etc/openhab2/scripts/therm.py -h " + receivedCommand)
// Sync Setpoint with the set temp app
rule "Update Temp App"
Item IndHeat received command
IndHeatSet.postUpdate(IndHeat.state)
And the 2 scripts placed in etc\openhab2\scripts folder of my openhab2 installation
therm.py
#!/usr/bin/python
# By Brad Goodman
# http://www.bradgoodman.com/
# brad@bradgoodman.com
####################### Fill in settings below #######################
USERNAME="yourusername"
PASSWORD="yourpassword"
DEVICE_ID=deviceid
############################ End settings ############################
import urllib2
import urllib
import json
import datetime
import re
import time
import math
import base64
import time
import httplib
import sys
import getopt
import os
import stat
import subprocess
import string
AUTH="https://mytotalconnectcomfort.com/portal"
cookiere=re.compile('\s*([^=]+)\s*=\s*([^;]*)\s*')
def client_cookies(cookiestr,container):
if not container: container={}
toks=re.split(';|,',cookiestr)
for t in toks:
k=None
v=None
m=cookiere.search(t)
if m:
k=m.group(1)
v=m.group(2)
if (k in ['path','Path','HttpOnly']):
k=None
v=None
if k:
#print k,v
container[k]=v
return container
def export_cookiejar(jar):
s=""
for x in jar:
s+='%s=%s;' % (x,jar[x])
return s
def get_login(action, value=None):
cookiejar=None
#print
#print
#print "Run at ",datetime.datetime.now()
headers={"Content-Type":"application/x-www-form-urlencoded",
"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8",
"Accept-Encoding":"sdch",
"Host":"mytotalconnectcomfort.com",
"DNT":"1",
"Origin":"https://mytotalconnectcomfort.com/portal",
"User-Agent":"Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36"
conn = httplib.HTTPSConnection("mytotalconnectcomfort.com")
conn.request("GET", "/portal/",None,headers)
r0 = conn.getresponse()
#print r0.status, r0.reason
for x in r0.getheaders():
(n,v) = x
#print "R0 HEADER",n,v
if (n.lower() == "set-cookie"):
cookiejar=client_cookies(v,cookiejar)
#cookiejar = r0.getheader("Set-Cookie")
location = r0.getheader("Location")
retries=5
params=urllib.urlencode({"timeOffset":"240",
"UserName":USERNAME,
"Password":PASSWORD,
"RememberMe":"false"})
#print params
newcookie=export_cookiejar(cookiejar)
#print "Cookiejar now",newcookie
"DNT":"1",
"Origin":"https://mytotalconnectcomfort.com/portal/",
"Cookie":newcookie,
conn.request("POST", "/portal/",params,headers)
r1 = conn.getresponse()
#print r1.status, r1.reason
for x in r1.getheaders():
(n,v) = x
#print "GOT2 HEADER",n,v
#print "Cookiejar now",cookie
location = r1.getheader("Location")
if ((location == None) or (r1.status != 302)):
#raise BaseException("Login fail" )
print("ErrorNever got redirect on initial login status={0} {1}".format(r1.status,r1.reason))
return
# Skip second query - just go directly to our device_id, rather than letting it
# redirect us to it.
code=str(DEVICE_ID)
t = datetime.datetime.now()
utc_seconds = (time.mktime(t.timetuple()))
utc_seconds = int(utc_seconds*1000)
#print "Code ",code
location="/portal/Device/CheckDataSession/"+code+"?_="+str(utc_seconds)
#print "THIRD"
headers={
"Accept":"*/*",
"DNT":"1",
#"Accept-Encoding":"gzip,deflate,sdch",
"Accept-Encoding":"plain",
"Cache-Control":"max-age=0",
"Accept-Language":"en-US,en,q=0.8",
"Connection":"keep-alive",
"Referer":"https://mytotalconnectcomfort.com/portal/",
"X-Requested-With":"XMLHttpRequest",
"User-Agent":"Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36",
"Cookie":cookie
conn.set_debuglevel(999);
#print "LOCATION R3 is",location
conn.request("GET", location,None,headers)
r3 = conn.getresponse()
if (r3.status != 200):
print("Error Didn't get 200 status on R3 status={0} {1}".format(r3.status,r3.reason))
return
# Print thermostat information returned
if (action == "status"):
#print r3.status, r3.reason
rawdata=r3.read()
j = json.loads(rawdata)
#print "R3 Dump"
#print json.dumps(j,indent=2)
#print json.dumps(j,sort_keys=True,indent=4, separators=(',', ': '))
#print "Success:",j['success']
#print "Live",j['deviceLive']
print "Indoor Temperature:",j['latestData']['uiData']["DispTemperature"]
#print "Indoor Humidity:",j['latestData']['uiData']["IndoorHumidity"]
#print "Cool Setpoint:",j['latestData']['uiData']["CoolSetpoint"]
print "Heat Setpoint:",j['latestData']['uiData']["HeatSetpoint"]
print "Hold Until :",j['latestData']['uiData']["TemporaryHoldUntilTime"]
# print "Status Cool:",j['latestData']['uiData']["StatusCool"]
print "Status Heat:",j['latestData']['uiData']["StatusHeat"]
#print "Status Fan:",j['latestData']['fanData']["fanMode"]
return
headers={
"Accept":'application/json; q=0.01',
"DNT":"1",
'Content-Type':'application/json; charset=UTF-8',
'Referer':"/TotalConnectComfort/Device/CheckDataSession/"+code,
"Cookie":cookie
# Data structure with data we will send back
payload = {
"CoolNextPeriod": None,
"CoolSetpoint": None,
"DeviceID": DEVICE_ID,
"FanMode": None,
"HeatNextPeriod": None,
"HeatSetpoint": None,
"StatusCool": 0,
"StatusHeat": 0,
"SystemSwitch": None
# Calculate the hold time for cooling/heating
# t = datetime.datetime.now();
# stop_time = ((t.hour+hold_time)%24) * 60 + t.minute
# stop_time = stop_time/15
# Modify payload based on user input
if (action == "cool"):
payload["CoolSetpoint"] = value
payload["StatusCool"] = 1
payload["StatusHeat"] = 1
payload["CoolNextPeriod"] = 99
if (action == "heat"):
payload["HeatSetpoint"] = value
payload["HeatNextPeriod"] = 'null'
if (action == "cancel"):
payload["StatusCool"] = 0
payload["StatusHeat"] = 0
if (action == "fan"):
payload["FanMode"] = value
# Prep and send payload
location="/portal/Device/SubmitControlScreenChanges"
rawj=json.dumps(payload)
conn = httplib.HTTPSConnection("mytotalconnectcomfort.com");
#print "R4 will send"
#print rawj
conn.request("POST", location,rawj,headers)
r4 = conn.getresponse()
if (r4.status != 200):
print("Error Didn't get 200 status on R4 status={0} {1}".format(r4.status,r4.reason))
return
else:
print "Success in configuring thermostat!"
# print "R4 got 200"
def printUsage():
print
print "Cooling: -c temperature -t hold_time"
print "Heating: -h temperature -t hold_time"
print "Status: -s"
print "Cancel: -x"
print "Fan: -f [0=auto|1=on]"
print
print "Example: Set temperature to cool to 80f for 1 hour: \n\t therm.py -c 80 -t 1"
print
print "If no -t hold_time is provided, it will default to one hour from command time."
print
def main():
if sys.argv[1] == "-s":
get_login("status")
sys.exit()
if sys.argv[1] == "-x":
get_login("cancel")
sys.exit()
if (len(sys.argv) < 3) or (sys.argv[1] == "-help"):
printUsage()
sys.exit()
if sys.argv[1] == "-c":
get_login("cool", sys.argv[2])
sys.exit()
if sys.argv[1] == "-h":
get_login("heat", sys.argv[2])
sys.exit()
if sys.argv[1] == "-f":
get_login("fan", sys.argv[2])
sys.exit()
if __name__ == "__main__":
import urllib2
import urllib
import json
import datetime
import re
import time
import math
import base64
import time
import httplib
import sys
import getopt
import os
import stat
import subprocess
import string
for t in toks:
k=None
v=None
if m:
k=m.group(1)
v=m.group(2)
k=None
v=None
if k:
#print k,v
container[k]=v
return container
s=""
for x in jar:
return s
def get_login(action, value=None, hold_time=0):
cookiejar=None
#print
#print
"DNT":"1",
(n,v) = x
retries=5
#print params
"DNT":"1",
"Cookie":newcookie,
(n,v) = x
return
code=str(DEVICE_ID)
#print "Code ",code
#print "THIRD"
headers={
"Accept":"*/*",
"DNT":"1",
"Cookie":cookie
#conn.set_debuglevel(999);
return
rawdata=r3.read()
#print "R3 Dump"
#print "Status Cool:",j['latestData']['uiData']["StatusCool"]
return
headers={
"DNT":"1",
"Cookie":cookie
payload = {
"FanMode": None,
"StatusCool": 0,
"StatusHeat": 0,
#t = datetime.datetime.now();
#stop_time = ((t.hour+hold_time)%24) * 60 + t.minute
#stop_time = stop_time/15
payload["CoolNextPeriod"] = 'null'
#print rawj
return
else:
def printUsage():
print
print "Status: -s"
print "Cancel: -x"
print
print
print
def main():
get_login("status")
sys.exit()
get_login("cancel")
sys.exit()
printUsage()
sys.exit()
sys.exit()
sys.exit()
sys.exit()
main()
tstat
#!/bin/bash
# Script by Jamie R. Cid
# jay@cidcomm.com
#Get data from MyTotalControl and send to OH. This grabs one copy of the data and stores it instead of doing it for every request below. That's how you get blocked ;)
echo Getting Data from MyTotalControl Website
/etc/openhab2/scripts/therm.py -s > /var/log/honeywell.log
TEMPDATA="/var/log/honeywell.log"
echo Checking Indoor Temp
TEMPSTATUS=$( grep "Indoor Temperature" $TEMPDATA | sed -n -e 's/^.*Indoor Temperature: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.1.250:8080/rest/items/IndTemp" -d "$TEMPSTATUS"
echo $TEMPSTATUS
echo Checking Heat Setpoint
HEATSTATUS=$( grep "Heat Setpoint" $TEMPDATA | sed -n -e 's/^.*Heat Setpoint: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.1.250:8080/rest/items/IndHeat" -d "$HEATSTATUS"
curl --header "Content-Type: text/plain" -X POST "http://192.168.1.250:8080/rest/items/IndHeatSet" -d "$HEATSTATUS"
echo $HEATSTATUS
echo Checking Hold Status
HOLDSTATUS=$( grep "Hold Until" $TEMPDATA | sed -n -e 's/^.*Hold Until : //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.1.250:8080/rest/items/IndHoldStatus" -d "$HOLDSTATUS"
echo $HOLDSTATUS
echo Checking Heat On/Off Status
HEATERSTATUS=$( grep "Status Heat" $TEMPDATA | sed -n -e 's/^.*Status Heat: //p')
curl --header "Content-Type: text/plain" -X POST "http://192.168.1.250:8080/rest/items/IndHeaterStatus" -d "$HEATERSTATUS"
echo $HEATERSTATUS
exit 0
Sorry for the long post but i hope it will help anyone want to implement it to openhab 2.3
Many thanks to jcid1 for the original config.
