`import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.openhab.model.script.actions.Timer //for the taking of input from the sitemap
import java.util.Date
import java.text.SimpleDateFormat
import org.joda.time.*
var Number Dusk = 18 //This is the hour after which lights should turn on when you walk in, 18 = 6:00 PM
var Number Dawn = 4 //This is when to stop turning on lights based on doors, not really dawn but after this time doors would only be for people leaving early so no need to turn lights on.
var autoOff = 1
//autoOff = (SirenWarningTime.state as DecimalType).intValue
//setup the siren
rule "Siren Configuration Initialization"
System started
postUpdate(SirenWarningTime, 5)
//sound the alarm after the wait period
rule "Alarm 2"
Item BackDoor changed
logInfo(“STDOUT”, “A door was just opened or closed.” )
if(DoorArmed.state == ON)
logInfo(“STDOUT”, “Door is armed, about to get the time delay from SirenWarningTime item.” )
logInfo(“STDOUT”, “Siren time to wait " + autoOff + " seconds.” )
SirenTimer = createTimer(now.plusSeconds(autoOff)) [|
if(DoorArmed.state == ON){
logInfo(“STDOUT”, “The timer is up and the door is armed.” )
sendCommand(Siren, ON)
logInfo(“STDOUT”, “Clear the SirenTimer variable” )
SirenTimer = null}
else{
sendCommand(Siren, OFF)
logInfo(“STDOUT”, “Timer ran out but the door is no longer armed.” )}
else{logInfo(“STDOUT”, “The alarm was not armed.” )}
rule "Alarm Off"
Item DoorArmed changed
if(DoorArmed.state == OFF){
sendCommand(Siren, OFF)}
//test any door changes option
rule "Doors have changed"
Item Doors changed
logInfo(“STDOUT”, “A door has in fact changed”)
//Vacation Mode Rules
rule "Not Home"
Time cron "0 33 21 * * ?"
if(VacationMode.state == ON){
sendCommand(LivingroomDimmer, 100)
logInfo( “file”, “Vacation mode, turning on the living room lights”)
else
logInfo( “file”, “Vacation mode not active”)
rule "Not Home 2"
Time cron "0 35 21 * * ?"
sendCommand(LivingroomDimmer, OFF)
logInfo( “file”, “Vacation mode, turning off the living room lights”)
else
//end Vacation Mode Rules
//end new stuff
//end new stuff
/* This rule removed for troubleshooting
rule "MyTimeSTamp"
var SimpleDateFormat df = new SimpleDateFormat( “YYYY-MM-dd HH:mm:ss” )
var String Timestamp = df.format( new Date() )
logInfo( “File”, Timestamp )
rule "Walk In Lights - Garage Door"
Item GarageDoor changed
if(GarageDoor.state == OPEN) {
logInfo( “file”, “door open, is it after dusk?”)
if(now.getHourOfDay >= Dusk) {
sendCommand(KitchenDimmer, ON);}
else {
logInfo( “file”, “door open, is it before dawn?”)
if(now.getHourOfDay <= Dawn){
rule "Walk In Lights - Front Door"
Item FrontDoor changed
if(FrontDoor.state == OPEN) {
sendCommand(LivingroomDimmer, ON);}
else {
/**This rule is for the alarm siren to go off when it is armed and the door is open
rule "Alarm"
if(DoorArmed.state == ON && BackDoor.state == OPEN)
if(BackDoor.state == CLOSED)
//2 rules to dim the boys lights at a given time
rule "Bedtime Reminder"
Time cron "0 45 21 * * ?"
sendCommand(Bedroom1Dimmer,60)
logInfo( “file”, “changing the lights based on the time”)
rule "Bedtime"
Time cron "0 5 22 * * ?"
sendCommand(Bedroom1Dimmer,OFF)
//Turn the boys lights on at a given time
rule "Wake up Routine"
Time cron "0 0 7 * * ?"
sendCommand(Bedroom1Dimmer,100)
end`
