I’m a newbie, but have configuring more and more on Openhab and have been terrified of SD Card failure on my Raspberry Pi. (I’ve taken the backups etc).
So I bought one of these on eBAY: https://support.hp.com/gb-en/document/c04017240
I’m in the UK and paid GBP 50 for it.
I use zirbee2mqtt and found the package needs an AMD64, which this box has.
The only slight issue was I could not get Debian to boot, so I used Ubuntu instead, other than that it works a treat.
My version is SSD, so there is a slight issue with burn out, however I understand that SSD have on board firmware to balance the load. Some versions have a SATA header for a hard disk, mine doesn’t. But with 3GB disk usage and a 16GB MSATA, I’m hoping it will last and have 32GB reserve coming in the post.
Ian
