I have the same problem as you, i think there is a mixup between “string” and “number” i dont know how to fix this, maybe there are someone with better coding skilles ???
Ok picture is delete here is the code
import { NextFunction, Request, Response } from “express”;
import { BaseRouter } from “./BaseRouter”;
import { LandroidDataset } from “./LandroidDataset”;
import { LandroidS } from “./LandroidS”;
class LandroidSRouter extends BaseRouter {
protected init(): void {
this.router.get(“/status”, this.status.bind(this));
this.router.post(“/start”, this.startMower.bind(this));
this.router.post(“/stop”, this.stopMower.bind(this));
this.router.post(“/pause”, this.pauseMower.bind(this));
this.router.put(“/set/rainDelay/:value”, this.setRainDelay.bind(this));
this.router.put(“/set/timeExtension/:value”, this.setTimeExtension.bind(this));
this.router.put(“/set/schedule/:weekday”, this.setSchedule.bind(this));
this.router.post(“/poll”, this.poll.bind(this));
private status(req: Request, res: Response, next: NextFunction): void {
let latestUpdate: LandroidDataset = LandroidS.getInstance().getLatestUpdate();
if (latestUpdate) {
res.status(200).send(latestUpdate.serialize());
} else {
this.internalServerError(res);
private startMower(req: Request, res: Response, next: NextFunction): void {
LandroidS.getInstance().startMower();
this.ok(res);
private stopMower(req: Request, res: Response, next: NextFunction): void {
LandroidS.getInstance().stopMower();
this.ok(res);
private pauseMower(req: Request, res: Response, next: NextFunction): void {
LandroidS.getInstance().pauseMower();
this.ok(res);
private setRainDelay(req: Request, res: Response, next: NextFunction): void {
let value = req.params.value; <------------------------------------------------ THIS IS string
try {
LandroidS.getInstance().setRainDelay(value); <------------------------------THIS IS number
this.ok(res);
} catch (e) {
this.badRequest(res, e.message);
private setTimeExtension(req: Request, res: Response, next: NextFunction): void {
try {
LandroidS.getInstance().setTimeExtension(value); <------------------------------THIS IS number
this.ok(res);
} catch (e) {
private setSchedule(req: Request, res: Response, next: NextFunction): void {
let weekday = req.params.weekday; <------------------------------------------------ THIS IS string
let payload = req.body;
try {
LandroidS.getInstance().setSchedule(weekday, payload); <------------------------------THIS IS number
this.ok(res);
} catch (e) {
private poll(req: Request, res: Response, next: NextFunction): void {
LandroidS.getInstance().poll();
this.ok(res);
export default new LandroidSRouter().router;
