Hi YuChem,
yes, I did it. Just for one PZEM-004T and a NodeMCU.
I received power consumption data via MQTT in OpenHAB.
You can take a look at my blogsite to get more details.
If you need any assistance, please reply to this post.
Bye
Marco
Hi YuChem,
Bye
Marco
I’ve discovered that Tasmota supports these. Select PZEM Send for Tx and PZEM Receive for Rx.
Number Electricity_POW_T "Energy kWh" (FirstFloor, Energy) {mqtt="<[mosquitto:tele/sonoff-pzem/SENSOR:state:JSONPATH($.ENERGY.Total)],<[mosquitto:stat/sonoff-pzem//STATUS8:state:JSONPATH($.StatusPWR.Total)]"}
Number Electricity_POW_YDay "Energy Yesterday" (FirstFloor, Energy) {mqtt="<[mosquitto:tele/sonoff-pzem/SENSOR:state:JSONPATH($.ENERGY.Yesterday)],<[mosquitto:stat/sonoff-pzem//STATUS8:state:JSONPATH($.StatusPWR.Yesterday)]"}
Number Electricity_POW_Day "Energy Today" (FirstFloor, Energy) {mqtt="<[mosquitto:tele/sonoff-pzem/SENSOR:state:JSONPATH($.ENERGY.Today)],<[mosquitto:stat/sonoff-pzem//STATUS8:state:JSONPATH($.StatusPWR.Today)]"}
Number Electricity_POW_P "Energy Power" (FirstFloor, Energy) {mqtt="<[mosquitto:tele/sonoff-pzem/SENSOR:state:JSONPATH($.ENERGY.Power)],<[mosquitto:stat/sonoff-pzem//STATUS8:state:JSONPATH($.StatusPWR.Power)]"}
Number Electricity_POW_A "Energy Current" (FirstFloor, Energy) {mqtt="<[mosquitto:tele/sonoff-pzem/SENSOR:state:JSONPATH($.ENERGY.Current)],<[mosquitto:stat/sonoff-pzem//STATUS8:state:JSONPATH($.StatusPWR.Current)]"}
Number Electricity_POW_V "Energy Voltage" (FirstFloor, Energy) {mqtt="<[mosquitto:tele/sonoff-pzem/SENSOR:state:JSONPATH($.ENERGY.Voltage)],<[mosquitto:stat/sonoff-pzem//STATUS8:state:JSONPATH($.StatusPWR.Voltage)]"}
Sitemap
Text item=Electricity_POW_T label="Energy Total [%.1f kWh]" icon="Energy"
Text item=Electricity_POW_YDay label="Energy Yesterday [%.1f kWh]" icon="Energy"
Text item=Electricity_POW_Day label="Energy Today [%.1f kWh]" icon="Energy"
Text item=Electricity_POW_P label="Energy Power [%.1f W]" icon="Energy"
Text item=Electricity_POW_A label="Energy Current [%.1f A]" icon="Energy"
Text item=Electricity_POW_V label="Energy Voltage [%.1f V]" icon="Energy"
Hello everybody…I’m back just for a little update on my project.
I used my first Sonoff 4ch to drive some lights. I made some modifications to be able to use the device through my standard wall buttons.
As usual, more details on my blog:
Step n. 2 of my previous post. Integrating Sonoff 4 channel with TASMOTA firmware in OpenHAB.
I use it for 1 internal light and 3 exterior lights.
As usual, details in my blog
Cheers
Hi sir, could you please kindly provide the mq4 sensor ino file? Thanks!
Hi @kevinshane,
Following the example at the following link
https://www.geekstips.com/mq4-sensor-natural-gas-methane-arduino/
I wrote a class to interface MQ4 Gas sensor with my NodeMCU. See files
https://drive.google.com/open?id=14x7qp6Ohoj3SoKq7XhQGH9AtancW81_P
https://drive.google.com/open?id=1zLmphzwmfJ_HfRQDUt8iWYkhCLYuoqAJ
This is an example of utilization:
#define MQ4PIN A0
DDMQ4 mq4Sensor(MQ4PIN);
void setup() {
pinMode(MQ4PIN, INPUT);
void loop() {
DDMQ4Val gasValue = mq4Sensor.getValue();
In gasValue .ppm you get the value.
I hope it will be useful.
Cheers
Hello everybody…just a little step to keep going on in my setup.
I was able to use two PZEM-004T with a single Nodemcu ESP8266…and, of course, all integrated in OpenHAB!!!
I used two PZEM-004T to monitor my photovoltaic production and the energy consumption of the basement…Then I also added to my device a simple DHT11 for temperature and humidity data (I already know that DHT11 is not a good sensor, but for my purposes it’s enough)
My central unit is a NodeMcu ESP8266 Lolin v.3…and it works perfectly.
This is the output from my Basic UI
And this is the chart in grafana
Cheers
Another little step forward…
Automating a floor lamp…Using SONOFF, TASMOTA and OPENHAB
Monitor temperature and humidity using a DHT11 with SONOFF Basic
Details here
Cheers
It’s time to finalize what already done till now in my Home Automation System, based on OpenHAB 2
First thing to do is packaging the custom devices built with ESP8266 and sensors.
As usual more detail in my blog
Cheers
A little update on my current cleaning job on my personal blog.
Two PZEM-004T in one large box and a ESP8266 in a smaller one
Cheers
It’s time to try a google home assistant in my home automation.
I bought a Google Home Mini; I’m still testing it and in some days I will integrate it in OpenHAB…
Hi all,
I played a lot with google home and google assistant…and then I integrated it in my OpenHAB setup
Take a look at my blog for details
Cheers
oohhhh…It’s been a long time since my my last post … Exactly one year ago…
My setup keeps growing…just slower than usual…I hope to find time to update my blog with the last additions.
For now I leave a couple of shot about my last installation…the wall mounted HabPanel … using the fantastic Hab Panel Viewer.
Thanks to HabPanelViewer features and a Sonoff I built an autocharging system…So when the battery reaches 20% the sonoff turns on the power to charge till 99%
Last night I made some experiment to use a PZEM004T power meter with a SONOFF 4CH flashed with TASMOTA. It works veri well and so I can integrate in OpenHAB the power meter for the first floor that was missing in my house … the last one …
Using a SONOFF already installed to drive some lights at the first floor I can use a PZEM004T without adding another 5V power adapter to power up the serial of PZEM. I will use the 3.3V from the SONOFF itself.
Details on my blog
just an addendum to my last post… I published a video about my experiment with PZEM004T.
Here is it
Now I’m ready to integrate my last PZEM004T in my OpenHab System to monitor the first floor…the last floor without it I already have a Sonoff 4CH in the right place that is driving some lights…I would attach PZEM004T to it.
Finally I bought my first Sonoff Mini. As always I flashed it with TASMOTA firmware, in order to integrate it in my OpenHAB system. With the DIY mode, it’s very easy to upload a firmware without touch anything (just a jumper )
More details on my blog:
My Gazebo has lights
They are controlled by a SONOFF Basic flashed with TASMOTA which has also a temperature sensor (DS18B20)
And naturally it is in my OpenHAB System…
Cheers
Another little update. I begin my experiments my my new SONOFF Mini flashed with TASMOTA.
I would like to integrate a DHT11, a very basic and cheap temperature and humidity sensor. So I decided to flash a custom version of TASMOTA Lite with the DHT11 support. I built this custom release from TASMOTA source and with Visual Studio Code and platformIO.
As usual details on my blog
