Hi all, i am resolving a myopenhab site issue, hopefully will have it resolved in just a few moments.
This has been resolved, although the service will be a bit slow for a while. Unfortunately a small code change triggered a restart of the process that handles OH connections, which was not intended (these web only deploys have been transparent to deploy in the past). I rolled back the release and will schedule for another time which i will announce on the forums before attempting as it will require a restart of the processes again.
Just an FYI, there has been good progress moving to Kubernetes on a new hosting provider, this will allow more modern deployment styles and truly separate the the processes in their own immutable containers.
Apologies for the interruption
Still experiencing disconnections … I will let you know
First issue at 7.26 PM CET
Andrea
As always, thanks for your efforts Dan!
FYI, my disconnects stopped about 20 minutes ago and myopenhab.org says I’m online, but I can’t connect via the Android app or issue commands to Google Home. I figure that’ll all come back soon enough.
Still disconnected, just reloaded OH, no improvements.
Andrea
20:03:38.129 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: xhr poll error
at io.socket.engineio.client.Transport.onError(Transport.java:63) [bundleFile:?]
20:03:38.144 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = b899cf42-5ef4-4405-bc4d-990cbc7b20f2, base URL = http://localhost:8080)
20:03:41.136 [INFO ] [control.internal.WebSocketConnection] - Web Socket error
java.nio.channels.AsynchronousCloseException: null
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.close(HttpConnectionOverHTTP.java:181) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_232]
at org.eclipse.jetty.client.AbstractConnectionPool.close(AbstractConnectionPool.java:208) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.DuplexConnectionPool.close(DuplexConnectionPool.java:237) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.close(HttpDestination.java:385) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.doStop(HttpClient.java:260) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStop(WebSocketClient.java:371) [bundleFile:9.4.20.v20190813]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection.close(WebSocketConnection.java:159) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$2.run(WebSocketConnection.java:184) [bundleFile:?]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_232]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_232]
20:03:53.195 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
at io.socket.engineio.client.transports.PollingXHR.access$100(PollingXHR.java:26) [bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[?:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[?:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93) ~[?:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[?:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[?:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:185) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:135) ~[?:?]
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32) ~[?:?]
... 3 more
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_232]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_232]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:1.8.0_232]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:975) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:933) ~[?:1.8.0_232]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) ~[?:1.8.0_232]
at okio.Okio$2.read(Okio.java:139) ~[?:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[?:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:345) ~[?:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:217) ~[?:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:211) ~[?:?]
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:189) ~[?:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:75) ~[?:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:45) ~[?:?]
... 3 more
20:03:53.217 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = b899cf42-5ef4-4405-bc4d-990cbc7b20f2, base URL = http://localhost:8080)
Something was not right with the processes, i’m guessing a few hogged up the mongo connection, i went ahead and restarted all the instances (11:23 am PDT) , so it’s going to be a bit until everyone connects again. I’ll keep watching it. Thanks for your patience . For now i would avoid restarting OH for at least the next 30 mins and just let it try to connect on its own.
The service looks healthy again, my own OH instance reconnected on its own. If yours did not you can try restarting the cloud binding (or restart OH) .
It started working again for me without needing a restart. Thanks!
Now everything’s fine thank you man
Hi, can someone help try “sync devices” function normal from Google Home? mine get result of “… Sorry, something went wrong while syncing OpenHAB” - this problem had lasted for days, others are OK, OK for myopenhab cloud connect, and OK for other voice command to OH from Google Assistant, thanks for help !
Never mind for the above issue, my “sync devices” is working now, all are function well.
