Hi Guys,
I’ve set up my.openHAB and I am using it successfully with the iOS App on my iPhone. I have made some rules for controlling my thermostats (temperature up at 1pm and down at 10pm). And just to make sure that these rules are executed correctly, I added a “sendbroadcastnotification” for a push-message on my iPhone. This works in nearly every case. Just one case doesn’t work, it’s the rule at 10pm. No message is sent there. While investigating this issue, I found out that the my.openhab service/binding disconnects and reconnects constantly every 4 hours at full hours. This seems to be normal. And just at 10pm this reconnect also happens every day. And I assume, that’s the reason why the notification from the rule isn’t transmitted. When I change the rule to execute at 9.45pm, the push message appears.
Isn’t there some kind of queue, that a “lost” message could not happen? Personally I can live with the workaround in changing the time slightly. But maybe there are other situations where a lost message is more severe?
