I have followed many of existing open thread on myopenhab cloud services. it looks to me very fragile addon/cloud service that does not works out of box.
As of now, I could not see any event,device -status : offline in myopenhab. I have spend 3 days in debug various option but no luck.
Server/configurations/openhab_default.cfg has following configuration - Anything else required ??
security:option=EXTERNAL
security:netmask=192.168.1.0/24
persistence:default=myopenhab -
configurations/persistence/myopenhab.persist -
// persistence strategies have a name and a definition and are referred to in the “Items” section
Strategies {
// for rrd charts, we need a cron strategy
//everyMinute : "0 * * * * ?"
default = everyChange
Items {
// persist all items every hour and on every change
* : strategy = everyChange
3.Server/webapps/static has uuid & secret file. I have double / thrice confirmed that both are same in myopenhab account section too.
- Most IMP - Java Version -
I have downloaded latest Java from http://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.html . It’s Linux ARM 32 Hard Float ABI & jdk-8u101-linux-arm32-vfp-hflt.tar.gz
output of Java -version command
java version "1.8.0_65"
Java™ SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot™ Client VM (build 25.65-b01, mixed mode)
- Please see openhab log
12:01:37.046 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'myopenhab.persist’
12:01:37.067 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'db4o.persist’
12:01:37.087 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'rrd4j.persist’
12:01:37.105 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'logging.persist’
12:01:37.134 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'exec.persist’
12:01:37.278 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'demo.script’
12:01:37.564 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'demo.items’
12:01:37.693 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'demo.items’
12:01:37.719 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'demo.items’
12:01:38.993 [INFO ] [.o.u.w.i.servlet.WebAppServlet:80 ] - Started Classic UI at /classicui/openhab.app
12:01:39.671 [DEBUG] [.r.internal.RuleModelActivator:42 ] - Registered ‘rules’ configuration parser
12:01:39.702 [DEBUG] [m.r.internal.engine.RuleEngine:77 ] - Started rule engine
12:01:43.914 [DEBUG] [.m.i.MyOpenHABServiceActivator:28 ] - MyOpenHAB service has been started.
12:01:43.920 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:300 ] - setEventPublisher
12:01:43.921 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:135 ] - my.openHAB service activated
12:01:43.931 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing myopenhab persistence service.
12:01:43.990 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:118 ] - config is null
12:01:43.995 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:176 ] - UUID file found at ‘/home/pi/Desktop/Jititech_User/Server/webapps/static/uuid’ with content '8092f763-09fd-408c-8b33-5d198189a41d’
12:01:43.996 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:228 ] - Secret file already exists at ‘/home/pi/Desktop/Jititech_User/Server/webapps/static/secret’ with content 'temp1234@'
12:01:43.998 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:120 ] -
12:01:44.008 [DEBUG] [.m.internal.MqttitudeActivator:33 ] - Mqttitude binding has been started.
12:01:44.035 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:176 ] - UUID file found at ‘/home/pi/Desktop/Jititech_User/Server/webapps/static/uuid’ with content '8092f763-09fd-408c-8b33-5d198189a41d’
12:01:44.037 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:228 ] - Secret file already exists at ‘/home/pi/Desktop/Jititech_User/Server/webapps/static/secret’ with content 'temp1234@'
12:01:44.039 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:162 ] - Version file found at ‘/home/pi/Desktop/Jititech_User/Server/webapps/static/version’ with content '1.8.3’
12:01:44.077 [DEBUG] [.b.m.internal.MqttitudeBinding:84 ] - Activating Mqttitude binding
12:01:44.116 [DEBUG] [o.p.m.i.MqttPersistenceService:100 ] - Deactivating MQTT Persistence
12:01:44.119 [DEBUG] [o.p.m.i.MqttPersistenceService:81 ] - Configuration updated for MQTT Persistence.
12:01:44.120 [DEBUG] [o.p.m.i.MqttPersistenceService:88 ] - Activating MQTT Persistence
12:01:44.133 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing mqtt persistence service.
12:01:44.170 [DEBUG] [.myopenhab.internal.MyOHClient:138 ] - Manager.EVENT_TRANSPORT
12:01:44.241 [DEBUG] [.p.internal.PersistenceManager:428 ] - Scheduled strategy mqtt.everyHour with cron expression 0 0 * * * ?
12:01:44.247 [DEBUG] [.o.b.ntp.internal.NtpActivator:31 ] - NTP binding has been started.
12:01:44.272 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Date (Type=DateTimeItem, State=Uninitialized)’ with ‘NtpGenericBindingProvider’ reader.
12:01:44.303 [INFO ] [.service.AbstractActiveService:169 ] - NTP Refresh Service has been started
12:01:44.307 [DEBUG] [.i.LoggingPersistenceActivator:31 ] - Logging persistence bundle has been started.
12:01:44.352 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing logging persistence service.
12:01:44.376 [DEBUG] [.b.mqtt.internal.MqttActivator:34 ] - MQTT binding has been started.
12:01:44.423 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Relay1 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.472 [ERROR] [i.internal.GenericItemProvider:350 ] - Binding configuration of type ‘mqtt’ of item ‘Relay1‘ could not be parsed correctly.
org.openhab.model.item.binding.BindingConfigParseException: Configuration ‘localbroker:/openhabdemo/gpio/1:command:1’ is not a valid outbound configuration: Configuration requires 5 parameters separated by ':'
at org.openhab.binding.mqtt.internal.MqttMessagePublisher.(MqttMessagePublisher.java:91) ~[na:na]
at org.openhab.binding.mqtt.internal.MqttItemConfig.(MqttItemConfig.java:64) ~[na:na]
at org.openhab.binding.mqtt.internal.MqttGenericBindingProvider.processBindingConfiguration(MqttGenericBindingProvider.java:59) ~[na:na]
at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:348) [org.openhab.model.item_1.8.3.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:309) [org.openhab.model.item_1.8.3.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.addBindingConfigReader(GenericItemProvider.java:106) [org.openhab.model.item_1.8.3.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_65]
at org.eclipse.equinox.internal.ds.model.ComponentReference.bind(ComponentReference.java:376) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bindReference(ServiceComponentProp.java:444) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.dynamicBind(InstanceProcess.java:416) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:334) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:222) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:536) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:213) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
12:01:44.477 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Relay2 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.494 [ERROR] [i.internal.GenericItemProvider:350 ] - Binding configuration of type ‘mqtt’ of item ‘Relay2‘ could not be parsed correctly.
org.openhab.model.item.binding.BindingConfigParseException: Configuration ‘localbroker:/openhabdemo/gpio/2:command:1’ is not a valid outbound configuration: Configuration requires 5 parameters separated by ':'
12:01:44.498 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Relay3 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.569 [ERROR] [i.internal.GenericItemProvider:350 ] - Binding configuration of type ‘mqtt’ of item ‘Relay3‘ could not be parsed correctly.
org.openhab.model.item.binding.BindingConfigParseException: Configuration ‘localbroker:/openhabdemo/gpio/3:command:1’ is not a valid outbound configuration: Configuration requires 5 parameters separated by ':'
12:01:44.574 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Relay4 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.594 [ERROR] [i.internal.GenericItemProvider:350 ] - Binding configuration of type ‘mqtt’ of item ‘Relay4‘ could not be parsed correctly.
org.openhab.model.item.binding.BindingConfigParseException: Configuration ‘localbroker:/openhabdemo/gpio/4:command:1’ is not a valid outbound configuration: Configuration requires 5 parameters separated by ':'
12:01:44.598 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘mqttsw1 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.638 [DEBUG] [inding.ntp.internal.NtpBinding:84 ] - Got time from ptbtime1.ptb.de: Sunday, 4 September 2016 12:01:44 o’clock UTC
12:01:44.638 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ] - Loaded MQTT config for item ‘mqttsw1’ : 0 subscribers, 2 publishers
12:01:44.644 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘mqttsw2 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.646 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ] - Loaded MQTT config for item ‘mqttsw2’ : 0 subscribers, 2 publishers
12:01:44.647 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘mqttsw3 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.649 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ] - Loaded MQTT config for item ‘mqttsw3’ : 0 subscribers, 2 publishers
12:01:44.651 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘mqttsw4 (Type=SwitchItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
12:01:44.653 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ] - Loaded MQTT config for item ‘mqttsw4’ : 0 subscribers, 2 publishers
12:01:44.659 [DEBUG] [.myopenhab.internal.MyOHClient:143 ] - Transport.EVENT_REQUEST_HEADERS
12:01:44.676 [DEBUG] [m.internal.MqttEventBusBinding:68 ] - MQTT: Activating event bus binding.
12:01:44.695 [DEBUG] [xecPersistenceServiceActivator:33 ] - Exec persistence bundle has been started.
12:01:44.727 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing exec persistence service.
12:01:44.734 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:282 ] - store(Date), state = 2016-09-04T12:01:44
12:01:44.736 [DEBUG] [.myopenhab.internal.MyOHClient:478 ] - No connection, Item update is not sent
12:01:44.753 [DEBUG] [.p.internal.PersistenceManager:428 ] - Scheduled strategy exec.everyMinute with cron expression 0 * * * * ?
12:01:44.758 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:437 ] - Publishing message 1 to topic '/jititechboard/mqtt_store/'
12:01:44.760 [DEBUG] [o.p.m.i.MqttPersistenceService:147 ] - Published item state ‘2016-09-04T12:01:44’ for item 'Date’
12:01:44.764 [DEBUG] [.b.http.internal.HttpActivator:34 ] - HTTP binding has been started.
12:01:44.801 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Weather_Temperature (Type=NumberItem, State=Uninitialized)’ with ‘HttpGenericBindingProvider’ reader.
12:01:44.805 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Weather_Humidity (Type=NumberItem, State=Uninitialized)’ with ‘HttpGenericBindingProvider’ reader.
12:01:44.823 [INFO ] [.service.AbstractActiveService:169 ] - HTTP Refresh Service has been started
12:01:44.827 [DEBUG] [.o.b.http.internal.HttpBinding:163 ] - item ‘Weather_Humidity’ is about to be refreshed now
12:01:44.857 [DEBUG] [.rrd4j.internal.RRD4jActivator:31 ] - RRD4j persistence bundle has been started.
12:01:44.909 [DEBUG] [.p.rrd4j.internal.RRD4jService:395 ] - Unknown property name : org.openhab.persistence.rrd4j
12:01:44.912 [DEBUG] [.p.rrd4j.internal.RRD4jService:364 ] - config ‘objectClass’ should have the format 'name.configkey’
12:01:44.914 [INFO ] [.p.rrd4j.internal.RRD4jService:407 ] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
12:01:44.916 [DEBUG] [.p.rrd4j.internal.RRD4jService:405 ] - Created default_other = GAUGE heartbeat = 3600 min/max = NaN/NaN step = 1 6 archives(s) = [ MAX xff = 0.999 steps = 1 rows = 3600 MAX xff = 0.999 steps = 10 rows = 1440 MAX xff = 0.999 steps = 60 rows = 1440 MAX xff = 0.999 steps = 900 rows = 2880 MAX xff = 0.999 steps = 21600 rows = 1460 MAX xff = 0.999 steps = 86400 rows = 3650] 0 items(s) = []
12:01:44.918 [DEBUG] [.p.rrd4j.internal.RRD4jService:405 ] - Created default_numeric = GAUGE heartbeat = 60 min/max = NaN/NaN step = 60 6 archives(s) = [ AVERAGE xff = 0.5 steps = 1 rows = 480 AVERAGE xff = 0.5 steps = 4 rows = 360 AVERAGE xff = 0.5 steps = 14 rows = 644 AVERAGE xff = 0.5 steps = 60 rows = 720 AVERAGE xff = 0.5 steps = 720 rows = 730 AVERAGE xff = 0.5 steps = 10080 rows = 520] 0 items(s) = []
12:01:44.924 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing rrd4j persistence service.
12:01:44.933 [DEBUG] [.p.internal.PersistenceManager:315 ] - Item ‘NoOfLights’ does not exist.
12:01:45.012 [DEBUG] [g.openhab.io.net.http.HttpUtil:190 ] - About to execute 'http://weather.yahooapis.com/forecastrss?w=638242&u=c’
12:01:45.031 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:282 ] - store(All), state = Undefined
12:01:45.032 [DEBUG] [.myopenhab.internal.MyOHClient:478 ] - No connection, Item update is not sent
