my.openHAB persistence and remote access used to work but now I have no access.
This is the start sequence.
2016-08-28 22:14:10.706 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
2016-08-28 22:14:32.681 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-08-28 22:14:33.532 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-08-28 22:14:33.625 [INFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2016-08-28 22:14:33.640 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mybroker'
2016-08-28 22:14:37.502 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2016-08-28 22:14:40.786 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'myopenhab.persist'
2016-08-28 22:14:41.758 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2016-08-28 22:14:42.769 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'heating.items'
2016-08-28 22:14:43.901 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'main.items'
2016-08-28 22:15:07.327 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'main.sitemap'
2016-08-28 22:15:17.506 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-08-28 22:15:23.940 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-08-28 22:15:31.032 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'main.rules'
2016-08-28 22:15:37.016 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Available engines:
2016-08-28 22:15:37.187 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Oracle Nashorn
2016-08-28 22:15:37.196 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - jython
2016-08-28 22:15:37.227 [INFO ] [o.c.j.i.e.scriptmanager.Script] - Loading Script ruleslighting.py
2016-08-28 22:16:11.360 [INFO ] [o.c.j.i.e.scriptmanager.Script] - EngineName: jython
2016-08-28 22:16:20.617 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Engine found for File: ruleslighting.py
2016-08-28 22:16:20.750 [INFO ] [o.c.j.i.e.scriptmanager.Script] - Loading Script rulesmedia.py
2016-08-28 22:16:20.783 [INFO ] [o.c.j.i.e.scriptmanager.Script] - EngineName: jython
2016-08-28 22:16:22.687 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Engine found for File: rulesmedia.py
2016-08-28 22:16:22.722 [INFO ] [o.c.j.i.e.scriptmanager.Script] - Loading Script rulesprayertimes.py
2016-08-28 22:16:22.740 [INFO ] [o.c.j.i.e.scriptmanager.Script] - EngineName: jython
2016-08-28 22:16:26.436 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Engine found for File: rulesprayertimes.py
2016-08-28 22:16:26.571 [INFO ] [o.c.j.i.e.scriptmanager.Script] - Loading Script rulesheating.py
2016-08-28 22:16:26.590 [INFO ] [o.c.j.i.e.scriptmanager.Script] - EngineName: jython
2016-08-28 22:17:21.093 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Engine found for File: rulesheating.py
2016-08-28 22:17:21.157 [INFO ] [o.c.j.i.e.scriptmanager.Script] - Loading Script rulesmain.py
2016-08-28 22:17:21.176 [INFO ] [o.c.j.i.e.scriptmanager.Script] - EngineName: jython
2016-08-28 22:17:21.644 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Engine found for File: rulesmain.py
2016-08-28 22:17:21.685 [INFO ] [o.c.j.i.e.scriptmanager.Script] - Loading Script rulesmisc.py
2016-08-28 22:17:21.701 [INFO ] [o.c.j.i.e.scriptmanager.Script] - EngineName: jython
2016-08-28 22:17:22.057 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Engine found for File: rulesmisc.py
2016-08-28 22:17:23.012 [WARN ] [.o.c.p.e.PersistenceExtensions] - There is no queryable persistence service registered with the name 'mysql'
2016-08-28 22:17:26.339 [INFO ] [.b.a.internal.bus.AstroBinding] - AstroConfig[latitude=XX.XXXXXX,longitude=-XX.XXXXXX,interval=60,systemTimezone=Europe/London (GMT +0100),daylightSavings=true]
2016-08-28 22:17:29.469 [INFO ] [.b.a.internal.job.JobScheduler] - Scheduled a daily job at midnight for astro calculation
2016-08-28 22:17:32.413 [ERROR] [b.m.internal.MqttitudeConsumer] - Unable to calculate relative location for PresenceSadaf_PhoneMqtt as there is no lat/lon configured for 'home'
2016-08-28 22:17:37.505 [INFO ] [o.o.b.w.i.common.WeatherConfig] - ProviderConfig[providerName=FORECASTIO,apiKey=XXXXXXXXXXXXXXXXXXX]
2016-08-28 22:17:37.540 [INFO ] [o.o.b.w.i.common.WeatherConfig] - LocationConfig[providerName=FORECASTIO,language=en,updateInterval=15,latitude=XX.XXXXXX,longitude=-XX.XXXXXX,woeid=<null>,locationId=home,name=Home]
2016-08-28 22:17:40.729 [INFO ] [.o.b.w.i.s.WeatherJobScheduler] - Starting and scheduling weatherJob-home with interval of 15 minutes
2016-08-28 22:17:58.977 [INFO ] [.service.AbstractActiveService] - Nest Refresh Service has been started
I have checked the UUID and secret.
After reading into the my.openHAB docs I found references to some configuration needed in the openhab.cfg file but there is no section for my.openHAB in the file.
I am using the Oracle java on a rasperry pi.
I am looking for some pointer on where the problem may come from.
PS
I have run on debug and this is the tail end.
23:03:08.982 [DEBUG] [o.i.r.i.resources.ItemResource:205 ] - Received HTTP POST request at 'items/LivingRoom_WallLights' with value 'OFF'.
23:03:08.995 [DEBUG] [.mqtt.internal.MqttItemBinding:44 ] - Publishing command OFF to /LivingRoom/WallLights
23:03:09.018 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:437 ] - Publishing message 15 to topic '/LivingRoom/WallLights'
23:03:11.337 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
23:03:11.358 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
23:03:14.089 [DEBUG] [o.i.r.i.resources.ItemResource:205 ] - Received HTTP POST request at 'items/LivingRoom_WallLights' with value 'ON'.
23:03:14.103 [DEBUG] [.mqtt.internal.MqttItemBinding:44 ] - Publishing command ON to /LivingRoom/WallLights
23:03:14.137 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:437 ] - Publishing message 16 to topic '/LivingRoom/WallLights'
23:03:14.606 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:281 ] - store(LivingRoom_WallLights), state = ON
23:03:14.624 [DEBUG] [.myopenhab.internal.MyOHClient:477 ] - No connection, Item update is not sent
23:03:14.823 [DEBUG] [.p.m.i.MysqlPersistenceService:412 ] - mySQL: Stored item 'LivingRoom_WallLights' as 'ON'[ON] in SQL database at Sun Aug 28 23:03:14 BST 2016.
23:03:14.833 [DEBUG] [.p.m.i.MysqlPersistenceService:414 ] - mySQL: query: INSERT INTO Item19 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;
23:03:16.587 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
23:03:16.604 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
23:03:21.824 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
23:03:21.850 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
23:03:27.032 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
23:03:27.053 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
23:03:32.283 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
23:03:32.307 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
23:03:37.563 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
23:03:37.579 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
23:03:43.113 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
23:03:43.136 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
And this is the my.OpenHAB starting sequence.
22:54:02.460 [DEBUG] [.m.i.MyOpenHABServiceActivator:27 ] - MyOpenHAB service has been started.
22:54:02.521 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:299 ] - setEventPublisher
22:54:02.532 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:134 ] - my.openHAB service activated
22:54:02.546 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:117 ] - config is null
22:54:02.585 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:175 ] - UUID file found at '/opt/openhab/webapps/static/uuid' with content 'XXXXXXXXXX'
22:54:02.608 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:227 ] - Secret file already exists at '/opt/openhab/webapps/static/secret' with content 'XXXXXXXXXXX'
22:54:02.622 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:119 ] - UUID = XXXXXXXXXX, secret = XXXXXXXXXX
22:54:02.696 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing myopenhab persistence service.
22:54:02.833 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:175 ] - UUID file found at '/opt/openhab/webapps/static/uuid' with content 'XXXXXXXXXXXX'
22:54:02.847 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:227 ] - Secret file already exists at '/opt/openhab/webapps/static/secret' with content 'XXXXXXXXXXXX'
22:54:02.874 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:161 ] - Version file found at '/opt/openhab/webapps/static/version' with content '1.8.3'
Sorry, lots of debugâŚ
