Good afternoon,
I had a sitemap working on openhab2 on Raspbian on Raspberry Pi 3 B+ and I added to my persistence rrd4j an item and then added the graph to the sitemap and when I enter to http://192.168.1.220:8080/basicui/app , the message shown is:
Welcome!
Available sitemaps
It seems like you have not defined any sitemaps yet. To build one, please check the documentation for guidance.
My sitemap is on openHAB2-conf\sitemaps and it worked until now.
This is my sitemap local.sitemap
sitemap local label="piDOMOhome" {
Frame label="Casa domòtica" {
Switch item=MotionTrig label="Activació alarma"
Switch item=Alarm label="Notificacions"
Default item=Door label="Porta"
Default item=Motion label="Moviment"
Switch item=Servo label="Motor"
Switch item=Light label="Llum"
Default item=Temperature label="Temperatura"
Default item=Humidity label="Humitat"
Default item=Luminosity label="Lluminositat"
Default item=Incendi label="Incendi"
Default item=Aigua label="Sensor d'inundació"
Frame label="Gràfic temperatura" {
Chart item=Temperature label="test" period=W refresh=1000
Frame label="Gràfic humitat" {
Chart item=,Humidity label="test" period=W refresh=1000
I would be greatful if someone could help me.
I have rebooted my Raspberry Pi 3 B+ and the problem’s the same.
Thanks a lot,
Josep
