I’m about creating a growing sitemap, and everything is fine. I’m heavily using visibility tags, summary items and groups. Here’s a partly screenshot of my freshly reloaded sitemap:
My sitemap starts with a “Image” element: it embeds a JPG. My camera re-creates this image every minute, and the sitemap seems to recognize when there’s a newer version of the image; then the sitemap reloads itself, and the new image is displayed. Ok so far. But every time it reloads, the sitemap gets a bit more puzzled:
I tested Firefox and Chrome, both are affected. I could not notice this behaviour without my picture frame - it seems to cause this? Or is there a configuration flag I don’t know or something I’ve missed?
no, even system reboot makes no difference: I had to move my Image sitemap element into a sub menu, then everything works fine. Information perhaps interesting for @ThomDietrich and/ or @Kai?
Hey Marianne,
you tried to explain your issue as good as possible but I still don’t see the exact problem. Where is this Image element you are talking about Could you post your sitemap code (a reduced version)?
it was the “observation” image of my living room, that’s why I did not post it - don’t want images of my house publicly available But when it’s needed I can provide it by mail. I’ll attach part of the sitemap below - if the whole sitemap is needed, I also would prefer to send it by mail.
Thanks a lot!
Marianne
sitemap default label="Willkommen zu Hause" {
Image url="http://192.168.2.18:8080/static/Livecam.jpg"
//----- BELEUCHTUNG -----
Frame item=gLampen label="Beleuchtung [aktiv: %d]" {
//----- One switch to rule them all
Switch item=gLampen label="Alle Lampen im Haus" mappings=[OFF="Alle aus"]
//----- Beleuchtung im Wohnzimmer
Text item=gWohnzimmerlampen label="Wohnzimmer [aktiv: %d]" {
//-(7)- Hue Lichtband am Fernseher
Text label="Lichtband [Ambilight]" icon="screen" visibility=[Hue7_ShowInSitemap == 0]
Text item=Hue7_Schalter label="Lichtband [MAP(Beleuchtung.map):%s]" visibility=[Hue7_ShowInSitemap == 1] valuecolor=[ON="green", OFF="maroon"] {
Switch item=Hue7_Schalter label="Lichtband" mappings=[OFF="Aus", ON="Ein"]
Slider item=Hue7_Brightness label="Helligkeit" icon="light"
Slider item=Hue7_Colortemperature label="Farbtemperatur" icon="rgb"
Colorpicker item=Hue7_Color label="Farbton"
Text label="Lichtband [⛔]" icon="error" visibility=[Hue7_ShowInSitemap == 2]
//-(4)- Wohnzimmer // Eckleuchte // IKEA Tradfri Color:65541
// and many other lights... :)
//----- Alle Heizkörper & Temperaturen im Haus
Frame item=gHeizkoerper label="Heizkörper [im Durchschnitt: %.1f °C]" {
Text item=Boiler_Temp label="Kessel [%.1f °C]"
Text item=Hotwater_Temp label="Warmwasser [%.1f °C]"
//----- Fußbodenheizung Bad oben
Text item=Bad_1_Heizung_FAULT
label="Bad Fußbodenheizung [MAP(HM-CC-RT-DN.map):%s]"
icon="radiator"
visibility=[Bad_1_Heizung_FAULT != NO_FAULT]
valuecolor=[!=NO_FAULT="maroon"]
Text item=Bad_1_Heizung_Status label="Bad Fußbodenheizung [%s]" icon="radiator" visibility=[Bad_1_Heizung_Reachable == ON] {
Frame label="Temperatur" {
Text item=Bad_1_Heizung_ACTUALTEMP label="Aktuelle Temperatur [%.1f °C]"
Text item=Bad_1_Heizung_SET label="Solltemperatur [%.1f °C]"
Frame label="Heizkörper" {
Setpoint item=Bad_1_Heizung_SET label="Sollwert (±1) [%.1f °C]" minValue=4.5 maxValue=30.5 step=1.0 visibility=[Bad_1_Heizung_SET > 4.5]
Setpoint item=Bad_1_Heizung_SET label="Sollwert (±½) [%.1f °C]" minValue=4.5 maxValue=30.5 step=0.5 visibility=[Bad_1_Heizung_SET > 4.5]
Switch item=Bad_1_Heizung_SET label="Stellglied [OFF]" mappings=[5.0=Einschalten] visibility=[Bad_1_Heizung_SET == 4.5]
Switch item=Bad_1_Heizung_PRESET label="Schnellwahl" mappings=[0="Abgesenkt", 1="Komfort", 2="Warm"]
Switch item=Bad_1_Heizung_BOOSTMODE label="Boost (5min)" mappings=[ON="Starten"] visibility=[Bad_1_Heizung_BOOSTSTATE == 0]
Text item=Bad_1_Heizung_BOOSTSTATE label="Boost-Restzeit [%d min]" visibility=[Bad_1_Heizung_BOOSTSTATE > 0]
Text item=Bad_1_Heizung_VALVE label="Ventilstellung [%d %%]"
Text label="Thermostat Fußbodenheizung [⛔]" icon="error" visibility=[Bad_1_Heizung_Reachable != ON]
// all the other
