hi, everytime i am trying to add XML file of device generated from openhab, i am recieving XML parsing error.
what is the reason of this error?
Normally you can ignore the error. What device are you trying to configure?
i am trying to add this 6 channel dimmer FAX-0600, i ignore but the device not added
Can you post the file you are using so there’s no confusion as to where “here” actually is?
The XML was corrupted. I’ve fixed it and uploaded it.
i have other 2 device with the same brand, it means all this devices XML i generate from opehab was currupted?
but how it became corrupted?
can you please help to to add this XML file also, they have the same Error
FXA-5016 network_d4e729fa__node_6.xml (25.3 KB) FXA-5029 network_d4e729fa__node_5.xml (19.4 KB)
Please us an XML checker to find the error and update it. There are plenty of such checkers on line. The XML writer that OH uses sometimes writes some strings incorrectly so these just need changing.
i will do that thank you!
