Once a solution is available in HA / bimmer_connected, I can try to adapt our binding.
I have done as explained here - Using Captchas — bimmer_connected 0.17.0 documentation
It works, but after some time (1h) the token has to be generated again and the procedure repeated.
I think the manual solution is nice but doesn’t make too much sense as sustainable solution as the token will expire. The whole process must work completely automated.
@MartinOpenhabFan fully agree. Looking forward for any permanent solution.
I run bimmerconnected(0.17.0) via crontab every 15 minutes for 30 hours til now and have no need to generate token a second time.
can you share the scripts?
Sure, here it is.
be aware, that you have to initialize with :
bimmerconnected status --captcha-token CAPTCHA_TOKEN USERNAME PASSWORD REGION
one time.
I use only a few ITEM’s , hoping that sometimes the openhab Binding is working
#/bin/bash
curlput() { curl --header "Content-Type: text/plain" --request POST --data "$2" http://192.XX.XX.XX:8080/rest/items/$1 ; }
/home/openhabian/.local/bin/bimmerconnected status 'USERNAME' 'PASSWORD' rest_of_world > /home/openhabian/bmw_data
battery=`cat /home/openhabian/bmw_data |jq '.[].fuel_and_battery.remaining_battery_percent'`
curlput BMW_II3120_Range_BatterieLadestand $battery
chargestat=`cat /home/openhabian/bmw_data |jq '.[].fuel_and_battery.charging_status'`
curlput BMW_II3120_ChargingStatus $chargestat
chargeendtime=`cat /home/openhabian/bmw_data |jq '.[].fuel_and_battery.charging_end_time'`
curlput BMW_II3120_ChargingEndTime $chargeendtime
mileage=`cat /home/openhabian/bmw_data |jq '.[].mileage[0]'`
curlput BMW_II3120_Range_Tachostand $mileage
reichweite=`cat /home/openhabian/bmw_data |jq '.[].fuel_and_battery.remaining_range_electric[0]'`
curlput BMW_II3120_Range_ElektrischeReichweite $reichweite
BMWlat=`cat /home/openhabian/bmw_data |jq '.[].data.state.location.coordinates.latitude'`
BMWlon=`cat /home/openhabian/bmw_data |jq '.[].data.state.location.coordinates.longitude'`
BMWKoordinaten=`echo $BMWlat","$BMWlon`
curlput BMW_II3120_Koordinaten $BMWKoordinaten
curlput BMW_II3120_Koordinatengps $BMWKoordinaten
distance=`python3 /etc/openhab/scripts/coordistance.py $BMWlat $BMWlon`
curlput BMW_II3120_Distance_from_Home $distance
BMWhead=`cat /home/openhabian/bmw_data |jq '.[].data.state.location.heading'`
curlput BMW_II3120_Ausrichtung $BMWhead
BMWsecurity=`cat /home/openhabian/bmw_data |jq '.[].data.state.doorsState.combinedSecurityState'`
curlput BMW_II3120_Status_FahrzeugAbgeschlossen $BMWsecurity
BMWAdress=`cat /home/openhabian/bmw_data |jq '.[].data.state.location.address.formatted'`
curlput BMW_II3120_Adresse "$BMWAdress"
@dijannsen thank you!
looks it works.
I am using cron from openhab rules.
So my mistake was that the Authorization was done not from the openhab user but from openhabian.
I will be happy to use Python API rather then CLI, since CLI has not all the functions implemented (i.e. lock/unlock doors). But I am not succesful yet.
Are You successful with your Python API?
I have modified cli.py to 3 more functions (door_lock, door_unlock, climate_now), so this may be
a little help.
#!/usr/bin/python3
"""Simple executable to demonstrate and test the usage of the library."""
import argparse
import asyncio
import contextlib
import json
import logging
import sys
import time
from pathlib import Path
import httpx
from bimmer_connected import __version__ as VERSION
from bimmer_connected.account import MyBMWAccount
from bimmer_connected.api.regions import get_region_from_name, valid_regions
from bimmer_connected.const import DEFAULT_POI_NAME
from bimmer_connected.utils import MyBMWJSONEncoder, log_response_store_to_file
from bimmer_connected.vehicle import MyBMWVehicle, VehicleViewDirection
from bimmer_connected.vehicle.charging_profile import ChargingMode
TEXT_VIN = "Vehicle Identification Number"
def main_parser() -> argparse.ArgumentParser:
"""Create the ArgumentParser with all relevant subparsers."""
parser = argparse.ArgumentParser(
description=(f"Connect to MyBMW/MINI API and interact with your vehicle.\n\nVersion: {VERSION}"),
formatter_class=argparse.RawTextHelpFormatter,
parser.add_argument("--debug", help="Print debug logs.", action="store_true")
"--oauth-store",
help="Path to the OAuth2 storage file. Defaults to $HOME/.bimmer_connected.json.",
nargs="?",
metavar="FILE",
type=Path,
default=Path.home() / ".bimmer_connected.json",
parser.add_argument("--disable-oauth-store", help="Disable storing the OAuth2 tokens.", action="store_true")
subparsers = parser.add_subparsers(dest="cmd", description="Command", required=True)
subparsers.required = True
status_parser = subparsers.add_parser("status", description="Get the current status of the vehicle.")
status_parser.add_argument(
"-j", "--json", help="Output as JSON only. Removes all other output.", action="store_true"
status_parser.add_argument("-v", "--vin", help="Output data for specified VIN only.", type=str, nargs="?")
_add_default_arguments(status_parser)
_add_position_arguments(status_parser)
fingerprint_parser = subparsers.add_parser("fingerprint", description="Save a vehicle fingerprint.")
_add_default_arguments(fingerprint_parser)
_add_position_arguments(fingerprint_parser)
fingerprint_parser.set_defaults(func=fingerprint)
climate_parser = subparsers.add_parser('climate_now', description='Klimatisierung starten.')
_add_default_arguments(climate_parser)
climate_parser.add_argument('vin', help=TEXT_VIN)
climate_parser.set_defaults(func=climate_now)
door_lock_parser = subparsers.add_parser('door_lock', description='lock all doors.')
_add_default_arguments(door_lock_parser)
door_lock_parser.add_argument('vin', help=TEXT_VIN)
door_lock_parser.set_defaults(func=door_lock)
door_unlock_parser = subparsers.add_parser('door_unlock', description='unlock all doors.')
_add_default_arguments(door_unlock_parser)
door_unlock_parser.add_argument('vin', help=TEXT_VIN)
door_unlock_parser.set_defaults(func=door_unlock)
flash_parser = subparsers.add_parser("lightflash", description="Flash the vehicle lights.")
_add_default_arguments(flash_parser)
flash_parser.add_argument("vin", help=TEXT_VIN)
flash_parser.set_defaults(func=light_flash)
horn_parser = subparsers.add_parser("horn", description="Trigger the vehicle horn")
_add_default_arguments(horn_parser)
horn_parser.add_argument("vin", help=TEXT_VIN)
horn_parser.set_defaults(func=horn)
finder_parser = subparsers.add_parser("vehiclefinder", description="Update the vehicle GPS location.")
_add_default_arguments(finder_parser)
finder_parser.add_argument("vin", help=TEXT_VIN)
_add_position_arguments(finder_parser)
finder_parser.set_defaults(func=vehicle_finder)
chargingsettings_parser = subparsers.add_parser("chargingsettings", description="Set vehicle charging settings.")
_add_default_arguments(chargingsettings_parser)
chargingsettings_parser.add_argument("vin", help=TEXT_VIN)
chargingsettings_parser.add_argument("--target-soc", help="Desired charging target SoC", nargs="?", type=int)
chargingsettings_parser.add_argument("--ac-limit", help="Maximum AC limit", nargs="?", type=int)
chargingsettings_parser.set_defaults(func=chargingsettings)
chargingprofile_parser = subparsers.add_parser("chargingprofile", description="Set vehicle charging profile.")
_add_default_arguments(chargingprofile_parser)
chargingprofile_parser.add_argument("vin", help=TEXT_VIN)
"--charging-mode",
help="Desired charging mode",
nargs="?",
type=ChargingMode,
choices=[cm.value for cm in ChargingMode if cm != ChargingMode.UNKNOWN],
"--precondition-climate", help="Precondition climate on charging windows", nargs="?", type=bool
chargingprofile_parser.set_defaults(func=chargingprofile)
charge_parser = subparsers.add_parser("charge", description="Start/stop charging on enabled vehicles.")
_add_default_arguments(charge_parser)
charge_parser.add_argument("vin", help=TEXT_VIN)
charge_parser.add_argument("action", type=str, choices=["start", "stop"])
charge_parser.set_defaults(func=charge)
image_parser = subparsers.add_parser("image", description="Download a vehicle image.")
_add_default_arguments(image_parser)
image_parser.add_argument("vin", help=TEXT_VIN)
image_parser.set_defaults(func=image)
sendpoi_parser = subparsers.add_parser("sendpoi", description="Send a point of interest to the vehicle.")
_add_default_arguments(sendpoi_parser)
sendpoi_parser.add_argument("vin", help=TEXT_VIN)
sendpoi_parser.add_argument("latitude", help="Latitude of the POI", type=float)
sendpoi_parser.add_argument("longitude", help="Longitude of the POI", type=float)
sendpoi_parser.add_argument("--name", help="Name of the POI", nargs="?", default=DEFAULT_POI_NAME)
"--street", help="(optional, display only) Street & House No. of the POI", nargs="?", default=None
sendpoi_parser.add_argument("--city", help="(optional, display only) City of the POI", nargs="?", default=None)
"--postalcode", help="(optional, display only) Postal code of the POI", nargs="?", default=None
"--country", help="(optional, display only) Country of the POI", nargs="?", default=None
sendpoi_parser.set_defaults(func=send_poi)
sendpoi_from_address_parser = subparsers.add_parser(
"sendpoi_from_address", description=("Send a point of interest parsed from a street address to the vehicle.")
_add_default_arguments(sendpoi_from_address_parser)
sendpoi_from_address_parser.add_argument("vin", help=TEXT_VIN)
"-n", "--name", help="(optional, display only) Name of the POI", nargs="?", default=None
"-a", "--address", nargs="+", help="Address (e.g. 'Street 17, city, zip, country')"
sendpoi_from_address_parser.set_defaults(func=send_poi_from_address)
return parser
async def get_status(account: MyBMWAccount, args) -> None:
"""Get the vehicle status."""
if args.json:
for handler in logging.root.handlers[:]:
logging.root.removeHandler(handler)
await account.get_vehicles()
if args.json:
if args.vin:
print(json.dumps(get_vehicle_or_return(account, args.vin), cls=MyBMWJSONEncoder))
else:
print(json.dumps(account.vehicles, cls=MyBMWJSONEncoder))
else:
print(f"Found {len(account.vehicles)} vehicles: {','.join([v.name for v in account.vehicles])}")
for vehicle in account.vehicles:
if args.vin and vehicle.vin != args.vin:
continue
print(f"VIN: {vehicle.vin}")
print(f"Mileage: {vehicle.mileage.value} {vehicle.mileage.unit}")
print("Vehicle data:")
print(json.dumps(account.vehicles, cls=MyBMWJSONEncoder, indent=4))
def get_vehicle_or_return(account: MyBMWAccount, vin: str) -> MyBMWVehicle:
"""Get a vehicle by VIN or raise if not in account's vehicle list."""
vehicle = account.get_vehicle(vin)
if not vehicle:
valid_vins = ", ".join(v.vin for v in account.vehicles)
raise KeyError(f"Error: Could not find vehicle for VIN {vin}. Valid VINs are: {valid_vins}")
return vehicle
async def fingerprint(account: MyBMWAccount, args) -> None:
"""Save the vehicle fingerprint."""
time_dir = Path.home() / "vehicle_fingerprint" / time.strftime("%Y-%m-%d_%H-%M-%S")
time_dir.mkdir(parents=True)
account.config.log_responses = True
log_response_store_to_file(account.get_stored_responses(), time_dir)
print(f"fingerprint of the vehicles written to {time_dir}")
async def climate_now(account: MyBMWAccount, args) -> None:
"""Trigger the vehicle to start climate."""
vehicle = get_vehicle_or_return(account, args.vin)
status = await vehicle.remote_services.trigger_remote_air_conditioning()
print(status.state)
async def door_lock(account: MyBMWAccount,args) -> None:
"""Trigger the vehicle to lock doors its lights."""
status = await vehicle.remote_services.trigger_remote_door_lock()
print(status.state)
async def door_unlock(account: MyBMWAccount, args) -> None:
"""Trigger the vehicle to unlock doors its lights."""
status = await vehicle.remote_services.trigger_remote_door_unlock()
print(status.state)
async def light_flash(account: MyBMWAccount, args) -> None:
"""Trigger the vehicle to flash its lights."""
status = await vehicle.remote_services.trigger_remote_light_flash()
print(status.state)
async def horn(account: MyBMWAccount, args) -> None:
"""Trigger the vehicle to horn."""
status = await vehicle.remote_services.trigger_remote_horn()
print(status.state)
async def vehicle_finder(account: MyBMWAccount, args) -> None:
"""Trigger the vehicle finder to locate it."""
account.set_observer_position(args.lat, args.lng)
status = await vehicle.remote_services.trigger_remote_vehicle_finder()
print(status.state)
print({"gps_position": vehicle.vehicle_location.location, "heading": vehicle.vehicle_location.heading})
async def chargingsettings(account: MyBMWAccount, args) -> None:
"""Trigger a change to charging settings."""
if not args.target_soc and not args.ac_limit:
raise ValueError("At least one of 'charging-target' and 'ac-limit' has to be provided.")
status = await vehicle.remote_services.trigger_charging_settings_update(
target_soc=args.target_soc, ac_limit=args.ac_limit
print(status.state)
async def chargingprofile(account: MyBMWAccount, args) -> None:
"""Trigger a change to charging profile."""
if not args.charging_mode and not args.precondition_climate:
raise ValueError("At least one of 'charging-mode' and 'precondition-climate' has to be provided.")
status = await vehicle.remote_services.trigger_charging_profile_update(
charging_mode=args.charging_mode, precondition_climate=args.precondition_climate
print(status.state)
async def charge(account: MyBMWAccount, args) -> None:
"""Trigger a vehicle to start or stop charging."""
status = await getattr(vehicle.remote_services, f"trigger_charge_{args.action.lower()}")()
print(status.state)
async def image(account: MyBMWAccount, args) -> None:
"""Download a rendered image of the vehicle."""
for viewdirection in VehicleViewDirection:
if viewdirection == VehicleViewDirection.UNKNOWN:
continue
filename = (Path.cwd() / str(viewdirection.name).lower()).with_suffix(".png")
await asyncio.to_thread(filename.write_bytes, await vehicle.get_vehicle_image(viewdirection))
print(f"vehicle image saved to {filename}")
async def send_poi(account: MyBMWAccount, args) -> None:
"""Send Point Of Interest to car."""
poi_data = {
"lat": args.latitude,
"lon": args.longitude,
"name": args.name,
"street": args.street,
"city": args.city,
"postal_code": args.postalcode,
"country": args.country,
await vehicle.remote_services.trigger_send_poi(poi_data)
async def send_poi_from_address(account: MyBMWAccount, args) -> None:
"""Create Point of Interest from OSM Nominatim and send to car."""
query = [(str(" ".join(args.address)))]
try:
async with httpx.AsyncClient() as client:
response: httpx.Response = await client.get(
"https://nominatim.openstreetmap.org",
params={"q": query, "format": "json", "addressdetails": 1, "limit": 1},
response_json = response.json()[0]
except IndexError:
print("\nAddress not found")
sys.exit(1)
address = response_json.get("address", {})
city = address.get("city")
town = address.get("town")
poi_data = {
"lat": response_json["lat"],
"lon": response_json["lon"],
"name": args.name,
"street": address.get("road"),
"city": town if city is None and town is not None else None,
"postal_code": address.get("postcode"),
"country": address.get("country"),
def _add_default_arguments(parser: argparse.ArgumentParser):
"""Add the default arguments username, password, region to the parser."""
parser.add_argument("username", help="Connected Drive username")
parser.add_argument("password", help="Connected Drive password")
parser.add_argument("region", choices=valid_regions(), help="Region of the Connected Drive account")
"--captcha-token", type=str, nargs="?", help="Captcha token required for North America and Rest of World."
def _add_position_arguments(parser: argparse.ArgumentParser):
"""Add the lat and lng attributes to the parser."""
parser.add_argument("lat", type=float, nargs="?", const=0.0, help="(optional) Your current GPS latitude (as float)")
"lng", type=float, nargs="?", const=0.0, help="(optional) Your current GPS longitude (as float)"
parser.set_defaults(func=get_status)
def main():
"""Get arguments from parser and run function in event loop."""
parser = main_parser()
args = parser.parse_args()
if args.debug:
logging.basicConfig(level=logging.DEBUG)
logging.getLogger("asyncio").setLevel(logging.WARNING)
account = MyBMWAccount(
args.username, args.password, get_region_from_name(args.region), hcaptcha_token=args.captcha_token
if args.oauth_store.exists():
with contextlib.suppress(json.JSONDecodeError):
account.set_refresh_token(**json.loads(args.oauth_store.read_text()))
loop = asyncio.get_event_loop()
try:
loop.run_until_complete(args.func(account, args))
except Exception as ex: # pylint: disable=broad-except
sys.stderr.write(f"{type(ex).__name__}: {ex}\n")
sys.exit(1)
if args.disable_oauth_store:
return
args.oauth_store.parent.mkdir(parents=True, exist_ok=True)
args.oauth_store.write_text(
json.dumps(
"refresh_token": account.config.authentication.refresh_token,
"gcid": account.config.authentication.gcid,
"access_token": account.config.authentication.access_token,
if __name__ == "__main__":
main()
@dijannsen CLI is acctually python;)
Looking how the CLI code is done I have made it this way:
import asyncio
import json
from bimmer_connected.api.regions import Regions
file_path = "/var/lib/openhab/.bimmer_connected.json"
async def main():
# hcaptcha_token is only required for the first login, see the captcha documentation
account = MyBMWAccount(USERNAME, PASSWORD, Regions.REST_OF_WORLD)
# Open the file and load the data
with open(file_path, "r") as file:
data = json.load(file)
account.set_refresh_token(data["refresh_token"], data["gcid"], data["access_token"])
vehicle = account.get_vehicle(VIN)
print(vehicle.brand, vehicle.name, vehicle.vin)
result = await vehicle.remote_services.trigger_remote_light_flash()
print(result.state)
# Save the data to file
data={"refresh_token": account.config.authentication.refresh_token,"gcid": account.config.authentication.gcid,"access_token": account.config.authentication.access_token}
with open(file_path, "w") as file:
json.dump(data, file, indent=4)
asyncio.run(main())
it should be run as openhab user to test it:
sudo -u openhab bin/python FILE.py
Later you might use rule which reads the data and assign to the items.
You can access all the vehicle data, i.e.:
vehicle = account.get_vehicle("VIN")
doors_lock = vehicle.doors_and_windows.door_lock_state.split()[0]
doors_status = vehicle.doors_and_windows.all_lids_closed
windows_status = vehicle.doors_and_windows.all_windows_closed
battery_level = vehicle.fuel_and_battery.remaining_battery_percent
charging_target = vehicle.fuel_and_battery.charging_target
plug_state = vehicle.fuel_and_battery.is_charger_connected
charging_status = vehicle.fuel_and_battery.charging_status.split()[0]
and services, i.e.:
result = await vehicle.remote_services.trigger_remote_door_lock()
@dijannsen your CLI corrections are useful anyway. Thank you!
Good morning everyone. Are there any further guesses as to why the BMW binding no longer works? Thank you in advance.
