I’ve decided to try out Mycroft and the installation seemed to be very straight forward. My openHAB runs on a k3s cluster and Mycroft runs on a Raspberry Pi 4 at the moment (long term plan is to migrate Selene backend to k3s as well).
I have openhab skill installed on mycroft. I have a mirror of the public repository to a private repository - that’s why the skill ends in .bill
(mycroft cli log)
06:56:10.024 | DEBUG | 4614 | mycroft.skills.intent_service:_normalize_all_utterances:73 | Utterances: [('install openhab',)]
06:56:10.027 | DEBUG | 4614 | mycroft.skills.intent_services.padatious_service:_match_level:179 | Padatious Matching confidence > 0.95
06:56:10.076 | INFO | 4614 | msm.mycroft_skills_manager | Best match (0.61): openhab-mycroft.bill by
06:56:10.076 | ERROR | 4614 | SkillInstallerSkill | MSM failed: AlreadyInstalled(openhab-mycroft.bill)
When I refresh openhab items
it appears to successfully connect to the instance with a 200
return code, but an empty response.
06:58:53.465 | INFO | 4620 | __main__:handle_utterance:76 | Utterance: ['refresh openhab items']
06:58:53.477 | DEBUG | 4614 | mycroft.skills.intent_service:_normalize_all_utterances:73 | Utterances: [('refresh openhab items',)]
06:58:53.884 | DEBUG | 4614 | mycroft.skills.intent_services.padatious_service:_match_level:179 | Padatious Matching confidence > 0.95
06:58:53.921 | DEBUG | 4614 | urllib3.connectionpool | Starting new HTTP connection (1): 192.168.2.140:30081
06:58:53.949 | DEBUG | 4614 | urllib3.connectionpool | http://192.168.2.140:30081 "GET /rest/items?recursive=false HTTP/1.1" 200 None
192.168.2.140
is the openhab server and port 30081
is the ingress port for the cluster. I can GET
a response using postman:
(postman GET):
http://192.168.2.140:30081/rest/items?recursive=false HTTP/1.1
(postman RESPONSE):
"link": "http://192.168.2.140:30081/rest/items/uSF_light_20_Factor",
"state": "0.0",
"stateDescription": {
"step": 1.0,
"pattern": "%.1f",
"readOnly": true,
"options": []
"editable": false,
"type": "Number",
"name": "uSF_light_20_Factor",
"label": "Factor:",
"tags": [],
"groupNames": []
"link": "http://192.168.2.140:30081/rest/items/dSF_light_05_Watts",
"state": "0",
"step": 1.0,
"pattern": "%.1f W",
"readOnly": true,
"options": []
"editable": false,
"type": "Number",
"name": "dSF_light_05_Watts",
"label": "Power:",
"tags": [],
Obviously with a 200
response as well… I can also curl
the GET request from the Raspi 4 successfully.
I’ve set the host and port on both the https://home.mycroft.ai/skills
interface and the config file - and each one separately. But I’m not getting a 404
error.
I can’t figure out what isn’t connecting - - I’m guessing it is something very obvious that I just can’t put my finger on… Any help appreciated.
