oh, cool. thx. how does it work? do you have an example? thanks in advance!
For all those interested: the programmer of the binding is working on updating the binding and getting it into the OH distro in the coming weeks ā great news ![]()
The code will include sending the charge mode for the Zappi.
Hi Stephen. Sorry, that it took so long for me to get back to you.
Iām just making a few changes to support missing features and though Iād also incorporate the EDDI changes. However, I canāt see you PR. Did you submit this against my github repo?
Iāve renamed the branch to myenergi_binding_3.4.x to distinguish it from the work Iām doing for OH 4.0.
Otherwise, if you let me have your source code, Iāll figure out the changes myself.
Many thanks,
Rene
Just a quick update:
Iāve merged the support for Eddi contributed by @stephenc and made a couple of smaller changes to the Zappi code so that for example charge mode can be changed through the item as well as an new action.
Initial build seems to be working fine and Iām just tidying up my code a bit, complete any missing unit tests and then do a final 3.4.x build for the market place.
Once thatās published Iām planning to rebase on the main branch and submit the PR for the official 4.x distro.
Iāve just uploaded the latest build with Eddi and writable Zappi charging mode support. Let me know if everything work as expected or not.
Many thanks,
Rene
Thank you Rene for updating this binding ![]()
It seems to work for all other values / parametersā¦
The parameter:
chargingMode Number Boost, Fast, Eco or Eco+
How can this be set to STOP?
I can change between the settings⦠but not issue stop.
Also, despite the channel being a string, the item
is a string too, but shows a number (2 = ECO?!) in the item view.
(This could be just silly old me ānot getting itā)
Two maps for general interest:
zappi_command_status.map
1=trying
2=trying
3=trying
4=trying
5=trying
6=trying
7=trying
8=trying
9=trying
10=trying
254=ACK OK
255=Never sent
-=undefined
zappi_locking_mode.map
0=Locked now
2=Lock when plugged in
4=Locked when unplugged
8=Charge when locked
16=Charge session allowed, even when locked
-=undefined
Hi Max
Iām not sure, I understand what you mean with āStopā. There is no charging mode where itās stopped.
Regarding the charging mode, yes, this is how enumeration channels should be represented. The corresponding item definition is:
<channel-type id="chargingModeType">
<item-type>String</item-type>
<label>Charging Mode</label>
<description>The current charging mode of the device</description>
<state readOnly="false">
<options>
<option value="0">Boost</option>
<option value="1">Fast</option>
<option value="2">Eco</option>
<option value="3">Eco+</option>
</options>
</state>
</channel-type>
Behind the scenes, the item is represented by a string, but contains a numeric value. This allows for displaying the ānameā-equivalent (e.g. āFastā), but the item value is ā1ā.
If you want to change the charging mode through the console or in a script, you have to send it the corresponding numeric value as a string. e.g.
openhab> openhab:send Zappi_ChargingMode "3"
will set the mode to āEco+ā. Iāll extend the documentation a bit more, to make that clear.
The command status could potentially also be represented as an enumeration, but I didnāt see a big benefit, so just left it as a number.
<channel-type id="commandTriesType">
<item-type>Number</item-type>
<label>Command Status/Retries</label>
<description>0-10 Trying, 253 Acked and Failed, 254 Acked and OK, 255 No command has ever been sent</description>
<state readOnly="true" pattern="%d"/>
</channel-type>
The locking mode is a bitmap, so more than one bit can be set at any point in time. e.g. 12 = āLocked when unpluggedā as well as ācharge when lockedā.
To explain my use caseā¦
I charge with excess solar.
OH will provide me with generation, consumption and export values.
Once my home battery is at 95% and solar is >1.5kW then switch Zappi ECO ON.
Once the it is past 15:00 and the solar generation provides less than 1.5kW, switch the charging OFF = Stop; please see below.
[I use ECO instead of ECO+ to avoid the constant alerts that charging has stopped.]
Without the ability to issue STOP charging, this use case does not work ![]()
Number enumeration is perfect; allows users to show words in their native language.
Youāre right. I did a bit of digging and there seems to be now a STOP mode (with code 4) where the Zappi never charges. Iāll just add that into the code and build a new version. Should be available this evening.
Hope you had a great Easter break. I kept looking on your Google drive for the latest version, but the last one shown is from April 2.
It also seem that the myengi API seems to have problems, as I am getting 253s ever y30 seconds since 01:00 UTC+10. The app says the same.
As for the bitmap for the locking modes, maybe you can add the docu what these non-listed combinations may mean?!
Other than that, the binding seems to be working without fault.
The OH rules trigger ECO, and STOP; the latter of course fails until implemented. ![]()
Hi Max
Iāve uploaded a new version just before Easter (8th April), this contains the STOP mode change. Let me know if you still canāt see it on the drive.
Iāll have a look if I can find anything about the nightly issue around 1am. Iām getting the same and then it recovers again after a while. Maybe some maintenance window on the Myenergi servers.
Kind regards,
Rene
Thank you⦠browser refresh shows new jar⦠installed⦠works. ![]()
I think the API errors where on their end⦠these showed in their app as wellā¦
I also noticed, compared to the channels listed in your O.P. this channel:
<channel id="status" typeId="statusType"/>
⦠seems missing.
The following was observed on 2023-04-16 12:03 UTC+10, which seems another problem at their end? Not sure if and how to improve on this error message.
2023-04-16 12:03:52.547 [INFO ] [.myenergi.internal.MyEnergiApiClient] - Re-initializing Api connection after exception caught
java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@6e43ea::DecryptedEndPoint@13979da{l=/192.168.1.5:49080,r=s18.myenergi.net/54.195.158.93:443,OPEN,fill=-,flush=-,to=31604/0}
Caused by: java.io.EOFException: HttpConnectionOverHTTP@6e43ea::DecryptedEndPoint@13979da{l=/192.168.1.5:49080,r=s18.myenergi.net/54.195.158.93:443,OPEN,fill=-,flush=-,to=31604/0}
2023-04-16 12:03:55.581 [INFO ] [.myenergi.internal.MyEnergiApiClient] - Re-initializing Api connection after code: 0, reason:
2023-04-16 12:03:58.598 [INFO ] [.myenergi.internal.MyEnergiApiClient] - Re-initializing Api connection after code: 0, reason:
2023-04-16 12:04:01.608 [WARN ] [al.handler.MyEnergiBaseDeviceHandler] - Exception from API - myenergi:zappi:api:16181111
org.openhab.binding.myenergi.internal.exception.ApiException: Http error after several attemps: 0 -
thanks for providing this Binding.
Iāve managed to install it in my Docker-Based Openhab 4.1 installation.
First Iāve create an API Key on the myenergi webpage und then I created a things file in the corresponding folder.
Used my Myenergi Webpage login and password for the file and updated the serial numbers for my Zappi and the Harvi.
After saving the things file I get the following error message: {hubSerialNumber=Der Parameter wird benƶtigt.}
But I canāt find a place to enter a hub serial number.
Is the API Key also need for the configuration? Iāve tried to use it a username or password but always the same problem ![]()
2024-02-05 20:12:43.507 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myenergi:bridge:api' changed from UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): {hubSerialNumber=Der Parameter wird benƶtigt.} to UNINITIALIZED
2024-02-05 20:12:43.512 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myenergi:bridge:api' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2024-02-05 20:12:45.939 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myenergi:bridge:api' changed from UNINITIALIZED (DISABLED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): {hubSerialNumber=Der Parameter wird benƶtigt.}
Thatās my things file:
Bridge myenergi:bridge:api "MyEnergi API Bridge" [ username="MYUSERNAME", password="MYPASSWORD", refreshInterval=24 ] {
Thing zappi 21088888 "MyEnergi Zappi" [ refreshInterval=30 ]
Thing harvi 1947777 "MyEnergi Harvi" [ refreshInterval=30 ]
Appreciate your help ![]()
The hub serial number goes into the API bridge thing.
UID: myenergi:bridge:api
label: myenergi API Bridge
thingTypeUID: myenergi:bridge
configuration:
hubSerialNumber: "12345678"
refreshInterval: 24
password: PanucD3IxZkKI8uOx796gXTX
Meaning you have two things:
- API thing
- Zappi thing
Hi @Max_G,
thanks so much.
I finally got it working.
Andy
Hi.
Can all of the energy values in kWh be sent to openhab? Iād like to look at having the increasing production, consumption and export energy values in kWh sent to an item for display.
Good morning.
I am using openHAB since some years where I integrated HAVC, Tado and SolarEdge inverter to show what I need in a custom dashboard.
3 months ago I installed a Zappi v2 wallbox and I am in trouble to add it to openHAB
Landscape:
openHAB 3.4.1
Zappi v2, the one that has not need to use the āhubā since it is embedded
What I did:
- logged in myenergi website and generated the API key
- downloaded org.openhab.binding.myenergi-3.4.3-SNAPSHOT.jar to /usr/share/openhab/addons
- then into things on the openHAB gui pops up the Myenergi API bridge
- filled the field with the Zappi serial number
- filled the password field with the API key
I get this error:
Authentication Error (Invalid API key or account number)
I do not know where is the fault.
Maybe this integration works just with the Zappi connected to the Myenergi traditional hub and does not work with the Zappi V2 that integrates the hub?
Looking at the Zappi config, there are 2 serial number:
- 12345678 (8 numbers) for the Zappi itself
- Z12345678 (same 8 numbers but āZā at the beginning) for the integrated hub
The API bridge provides the same error with both.
Help please
Do you have any plans to make myenergi an official binding?
And is there a means to instruct the Zappi to charge with a provided amperage?
My Zappi V2 has the hub in it and works. Check on the app for the serial number associated with the hub. My hub shows the same number as the Zappi (but just the numbers).
For reference Iām running 4.2.0-SNAPSHOT version of the add-on.
