I have just succesfully migrated my OH2.5 setup over to a OH3.3 setup which is all fine an dandy, but to put the icing on the cake i want to connect to MyopenHAB.org so I can connect remotely… but for some odd reason i cannot change the UUID and secret once i’m logged into the myopenHAB.org… The fields are simply not there under my account???
I have seen two videos on youtube on how to do it but when i log into my openhab.org the fields are missing and thus i cannot change the UUID and Sectret and thus get my new system “online”
is this your/the master account ? Accounts can have different roles. The master account is being used to register an OH instance. Besides that a user’s role can be regular user.
not even but only the master account seems to be able to do so.
My previous post is based on your feedback that the screenshots are different. Thus I logged in an detected the role menu in the users configuration.
Seaching for documentation I haven’t been able to find any on the openhab.org page so far but I found this Enable Remote Access to a Local openHAB Instance
Ok So we can agree that my account is missing the feature of inserting a new UUID and Secret.
Also I have tried to delete my account, thinking I needed to start all over, but this is not possible either???
So I guess I need some help from some body who is able to control and program the “inner works” of myopenhab.org web page in order to either fix my account or delete it so I can start all over.
Any body knows who I need to reach out to? or will the relevant people read this post?
I really would like to keep using the current mail for the account as it is used to inform me when various incidents occur
Just tried to log-in on the link you provided to myopenhab.org and I can not see the page you’re a showing (My Users) So i’m not able to add or see and overview of users on my account
As mentioned before i’m afraid there something wrong with my account, as mentioned earlier i cant even delete it to try to start all over…
You are most likely using an account in myopenHAB with the role of “user” and not “master”. You can create multiple users when logged in with the original account used to register. So it’s likely you have another email address for the main master user.
If you PM me the email you are using to login i may be able to help.
After Digital Dan gave the the right words then light dawned on med at I realised that i had another mail address as the Master account. (sorry Wolfgang & Russi did not pick that up on your reply’s even though you tried to point me in that direction as well)
After i figured out that i have a master mail account as well i could log into that one and set it all up
