since this morning my OpenHAB instance cannot connect to the openhabcloud.
i have restartet the bundle, the instance, the server.
i have reinstalled openhab from a fresh installation (with same uuid and secret)
i get no errors in the log - its still ‘offline’
Sometimes, the session is online but
remote access is not possible (Error 504 Gateway Time-out)
Alexa tells "device is not reachable’
my internet connection is well.
any public problems with the cloudservice at this time?
can anyone give me a tipp ?
ralph
When I executed a command via Amazon Alexa an hour ago it worked, kind of.
Alexa told me it could not reach the device, but the command was executed a minute later.
So it seems to me openHAB cloud is under heavy load.
I did not investigate this further.
apica
(Aaron)
June 20, 2019, 10:08am
4
I have the same problem. The OH status though reports everything is working
so…at this time we can stop searching the problem in our local systems an have to wait or is there a way to get more debug information. does anyone knows the correct loggername in openhab which has to be set to TRACE ?
Or , if I recall correctly, you can use the free code to set up your own cloud presence that would have less load.
this is not compatible with amazon alexa - right ?
i don’t think, that this is a load problem.
the problem occurs from one minute to the next…
possible that there is a problem with the cluster or the cluster connection?
hopefully that DigitalDan can fix it ??
Same problem here. Paid subscriptions with better availability would be nice.
You probably need to tag @digitaldan for him to spot your message
Fiftiz
(Yannis)
June 20, 2019, 10:59am
11
same here myopenhab is offline
I just did, in my reply to you…
But for furture use… Just just need to insert @ and write part of the username, then you´ll see names appearing.
Only if you keep a free tier. Not like Home Assistant that is only free for one month.
According to the docs at the link it is compatible with Alexa.
jfrank1845
(Jared Frank)
June 20, 2019, 12:37pm
17
you can run openhab-cloud yourself. The only caveat is that you need to then set up a developer amazon account and host a customized copy of the skill youself so you can direct it to your server rather than the public one.
ok - but this is not the solution for the problem.
i would use the public opencloud service…like since yesterday
now we have a Service Outage at http://status.openhab.org . So it’s certainly a common problem… ;-(
Hope there is somebody so freaky and have a look on it
digitaldan
(Dan Cunningham)
June 20, 2019, 2:21pm
20
I’m looking at it now. Its not clear what the issue is immediately as all servers are up and running, I’ll post back here when i have more info.
