Does myopenhab.org have problems again?
Its kinda weird. myopenhab.org say my openhab is offline. But I can see Event log updates fine??
It worked fine an hour ago, and then suddenly, offline.
By me also, the log says:
2018-11-27 15:06:51.444 [ERROR] [io.openhabcloud.internal.CloudClient] - Socket.IO error: {}
io.socket.engineio.client.EngineIOException: websocket error
at io.socket.engineio.client.Transport.onError(Transport.java:71) [236:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.transports.WebSocket.access$500(WebSocket.java:28) [236:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.transports.WebSocket$2$5.run(WebSocket.java:150) [236:org.openhab.io.openhabcloud:2.3.0]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [236:org.openhab.io.openhabcloud:2.3.0]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
Caused by: java.io.EOFException
at okio.RealBufferedSource.require(RealBufferedSource.java:59) ~[?:?]
at okio.RealBufferedSource.readByte(RealBufferedSource.java:72) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:115) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:104) ~[?:?]
at okhttp3.internal.ws.RealWebSocket.readMessage(RealWebSocket.java:97) ~[?:?]
at okhttp3.ws.WebSocketCall.createWebSocket(WebSocketCall.java:152) ~[?:?]
at okhttp3.ws.WebSocketCall.access$000(WebSocketCall.java:41) ~[?:?]
at okhttp3.ws.WebSocketCall$1.onResponse(WebSocketCall.java:97) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:126) ~[?:?]
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32) ~[?:?]
... 3 more
2018-11-27 15:06:51.469 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxx, base URL = http://localhost:8080)
After an Openhab restart it works again…
Okay thanks… Cant restart cause I´m not at home.
I observed the same, uninstall/install CloudConnector resolved the issue (ATM).
I didn´t have to unsinstall.
I just restartet my openhab server (terminal command: sudo systemctl restart openhab2.service).
Correct, however I didn’t want to stop openHAB.
I had to anyway, cause I had some zigbee problems (again). Restart seems to solve that as well
Am I the only one having issues with myopenhab?
Todays log is full of openhab cloud errors
2018-12-14 12:18:05.398 [ERROR] [io.openhabcloud.internal.CloudClient] - Socket.IO error: {}
at io.socket.engineio.client.Transport.onError(Transport.java:71) [217:org.openhab.io.openhabcloud:2.4.0.M7]
at io.socket.engineio.client.transports.WebSocket.access$500(WebSocket.java:28) [217:org.openhab.io.openhabcloud:2.4.0.M7]
at io.socket.engineio.client.transports.WebSocket$2$5.run(WebSocket.java:150) [217:org.openhab.io.openhabcloud:2.4.0.M7]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [217:org.openhab.io.openhabcloud:2.4.0.M7]
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) ~[?:?]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) ~[?:?]
at okio.Okio$2.read(Okio.java:138) ~[?:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:238) ~[?:?]
at okio.RealBufferedSource.request(RealBufferedSource.java:66) ~[?:?]
... 3 more
2018-12-14 12:18:05.472 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxx, base URL = http://localhost:8080)
2018-12-14 12:18:06.505 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxx, base URL = http://localhost:8080)
There are no problems reported at https://status.openhab.org/
Restarting openhab doesn’t solve the problem.
