I’m having real difficulty getting my.openhab to work.
The first issue I notice is that the system generates a UUID for me, but doesnt generate a secret file.
Secondly, i cannot find anything in the logs that suggests it is trying to load the org.openhab.io.myopenhab-1.8.0.jar file in my addons folder. I can see in the logs that the exec binding is loading fine, so openhab is at least loading some addons in that folder?
Simply go to http://randomkeygen.com/ and generate a random key. You can select between a wide selection of encryption keys. I would recommend going with at least a 128-bit wep key.
128-bit encryption will provide a sufficient security for our server (unless someone else can chime in). Go to your /etc/openhab/webapps/static folder and create a new file called “secret”.
Paste your secret key into the “secret” file.
