Hi There,
just realized, that the Login to myopenhab is not working properly. It cancels with a Gateway 504.
The Rest Service Still works, but i simply can not Login in via the Login Page.
http://status.openhab.org/ does not indicate any error.
Hi There,
Confirmed - same issue
Same here
same here
been getting this error all morning too.
It looks as if only the web interface was affected. My openHAB installation is connected.
Edit: now it works again
… and the error seems to be happening again this morning
At the moment I’m getting the same message. 504 Gateway Time-out (13:19, Germany)
EDIT: Now it is running again! (16:40, Germany)
EDIT: now again: 504 Gateway Time-out (18:40, Germany)
Really strange, status.openhab.org shows all green and the cloud server itself seems to work. Only the web interface seems to be affected.
@kai: do you know more about this problem?
@digitaldan is currently looking into it.
@kai @digitaldan Any news?
Today 15:33, Germany: 504 Gateway Time-out
I am still investigating this, I have enabled a workaround for the time being which should prevent the issue until a proper fix can be put into place.
Hi. Seems its down again. When trying alexa or mypenhab.com it goes for 504 Gateway Time-out
Same here. If I try to connect via the website it only shows ‘forbidden’ entering username and password.
I am experiencing the same issue today with the rest service I am able to login into myopenhab.org with no problem and status dashboard doesn’t show any issue.
I am having the same issue if that helps (as it proves it’s not your setup)
I’m sure it will be fixed soon.
