I have openhab 1.8.3 installed on a Pi Zero with java version 1.8.0_121
I’ve also followed the instructions for the myopenhab connector by pasting the whole thing at the bottom of the openhab.cfg file but myopenhab still doesn’t connect.
I’ve reinstalled a few times and check UUID and secret also.
If there’s anything more I should do, please let me know. Thank you.
There are no relevant errors and it shows that the binding it initializing but I don’t see either a connection successful or a connection failed. There are lots of errors indicating that the connection is not established when it tries to upload Item event state changes.
You can try uninstalling and reinstalling it to see if that makes a difference. I’m not sure what else it could be.
Are you using the Cloud Connector add-on? You should be seeing log statements like this:
2017-01-28 12:43:40.441 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = e47a83fc-7b30-4d20-ac24-8dc8c8102c22, base URL = http://localhost:8080)
Note the statement is coming from openhabcloud, not MyOpenhab
Are you running with the latest Oracle Java, at least version 1.8.0_111.
MQTT is completely independent from the MyOpenhab Cloud Connector. Have you also installed the MQTT Action? If so there is currently a bug that prevents the MQTT binding from working when the MQTT Action is also installed.
Nope, I have the cloud connector in my cfg but I’m not seeing anything related to it in the logs.
No, I only have mqtt binding installed.
apparently i didn’t follow the tutorials as closely as I should’ve in my rush to get this done. I’ve installed the cloud connector, everything works now. thank you
