Myopenhab only online / no offline events
myopenhab
Tags: #<Tag:0x00007f87662f9fc8>
(Micha Mueller) #1
I saw that for 7 days now, I only get online msgs from myopenhab.
Before, I always got a pair of first offline, then online events.
Are the offline events somehow delayed now and the online events not?
(Micha Mueller) #2
Anybody?
(Thomas Schlichting) #3
Yep I also have that - I am not even sure it actually has been offline…
(Martin Herbst) #4
Same problem here. Today I had to reboot my openHAB several times. I received one offline notifications and several online notifications. This is the list of my notifications:
Today at 8:45 PM openHAB is online
Today at 8:38 PM openHAB is online
Today at 8:30 PM openHAB is online
Today at 8:28 PM openHAB is online
Today at 8:25 PM openHAB is online
Today at 8:21 PM openHAB is online
Today at 8:15 PM openHAB is online
Today at 7:14 PM openHAB is offline
Today at 7:08 PM openHAB is online
(Micha Mueller) #5
Good to see it is no single situation here.
I am getting the online/offline events as push messages via Android app.
This seems to be a myopenhab bug since an offline event is much more important than an online event, right?
Myopenhab is not sending online and offline notifications
(Frantisek) #6
I have same issue… @rlkoshak, do you maybe have an idea what’s wrong?
Thanks!
(Rich Koshak) #7
Back in Feb when this thread was posted there were some problems with the myopenhab.org servers. I have no idea why you might be seeing these problems now. That has long since been fixed.
Look at your logs and make sure you are not seeing connect/disconnect events there.
(Micha Mueller) #8
Rich, you are right, “something” has been fixed - now we get no push notification about online or offline events at all. Is that the desired behaviour?
I would still expect getting offline events after some timeout - maybe not as short as back in Feb where you were “spammed” even if the local router cut the connection and reconnected after a minute, but after 15…30 min or maybe as setting.
(Rich Koshak) #9
I can’t say. I’ve been getting online and offline events. My OH hadn’t been offline in a couple of weeks so maybe something changed recently but the last time I took OH down I got the alert within a couple of minutes of OH going down.
(Dan Cunningham) #10
Hi, we had an issue with myopnehb this am where we had a server die, but not shutdown completely. We are currently researching monitoring solutions to help identify this much earlier then we did today.
(Micha Mueller) #11
Is this fixed now?
I still do not seem to get offline events.
F.e., I did an upgrade last weekend which forced openhab to shutdown for more than 5 minutes and did not get any push notification although this is how it should work (see http://www.myopenhab.org/).
(Andrew Wiczling) #12
Hi
I’m still not getting online/offline notifications from myopenhab, though the events do show in the event log. Is the problem fixed and I have to do something or is it still not working for everyone?
(Micha Mueller) #13
For me, it is still not working.
No notifications from openhab.
Only online events in the myopenhab event log.
(Rich Koshak) #14
An issue has been filed. Myopenhab.org online/offline notification
