Myopenhab.org items not updating: baseURL incorrect?
myopenhab.org is not updating items since late July.
In PaperUI, I changed the base URL to an incorrect value, and this change is recognized, causing the service to shutdown
08:18:11.475 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=388, mode=remote, service.bundleid=212, service.scope=bundle, service.config.label=openHAB Cloud, component.name=org.openhab.openhabcloud, component.id=184, baseURL=https://myopenhab.org/wut, service.config.category=io, service.pid=org.openhab.openhabcloud, service.config.description.uri=io:openhabcloud} - org.openhab.io.openhabcloud
08:18:12.865 [ERROR] [.io.openhabcloud.internal.CloudClient] - Socket.IO error: Invalid namespace
08:18:15.702 [WARN ] [ab.core.events.EventPublisherDelegate] - given new state is NULL, couldn’t post update for …
08:18:27.931 [DEBUG] [io.openhabcloud.internal.CloudService] - openHAB Cloud connector deactivated
08:18:27.935 [INFO ] [.io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
Then put in the correct value, causing the service to restart.
08:18:27.955 [DE BUG] [io.openhabcloud.internal.CloudService] - openHAB Cloud connector activated
08:18:27.960 [DEBUG] [io.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘xxx’
08:18:27.966 [DEBUG] [io.openhabcloud.internal.CloudService] - UUID = xxx, secret = xxx
08:18:27.971 [DEBUG] [io.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘xxx’
08:18:27.995 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=389, mode=remote, service.bundleid=212, service.scope=bundle, service.config.label=openHAB Cloud, component.name=org.openhab.openhabcloud, component.id=184, baseURL=https://myopenhab.org/, service.config.category=io, service.pid=org.openhab.openhabcloud, service.config.description.uri=io:openhabcloud} - org.openhab.io.openhabcloud
08:18:28.808 [DEBUG] [.io.openhabcloud.internal.CloudClient] - Socket.IO connected
08:18:28.813 [INFO ] [.io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxx, base URL = http://localhost:8080)
But notice it first indicates the base URL is correct, then later says it is http://localhost:8080
I’ve tried
  • uninstalling the service
  • stopping opnhab2
  • clearing the cache
  • restarting
  • reinstalling service, setting secret and UUID again
Is that incorrect baseURL spurious?
