Java Runtime Environment:
java version “1.8.0_65”
Java™ SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot™ Client VM (build 25.65-b01, mixed mode)
What do I have to do so that it is online
I do not know how to do it
To start with you need a version of 101 or higher. Yours is only version 65.
If you are on a Raspberry Pi if you do the following then when you use apt-get to update everything on your Pi in future then Java will get updated to.
But unable to remove old java. Console says
raspberrypi:~ $ sudo apt-get purge openjdk*
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘openjdk-7-jre’ for regex ‘openjdk*’
Note, selecting ‘openjdk-6-jre-headless’ for regex 'openjdk
Note, selecting ‘openjdk-8-dbg’ for regex ‘openjdk*’
Note, selecting ‘openjdk-jre’ for regex ‘openjdk*’
Note, selecting ‘uwsgi-plugin-jvm-openjdk-7’ for regex ‘ope
jdk*’
Note, selecting ‘openjdk-7-doc’ for regex ‘openjdk*’
Note, selecting ‘openjdk-7-jre-lib’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-jre’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-jre-zero’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-demo’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-doc’ for regex ‘openjdk*’
Note, selecting ‘openjdk-7-jre-headless’ for regex 'openjdk
Note, selecting ‘openjdk-7-demo’ for regex ‘openjdk*’
Note, selecting ‘openjdk-7-source’ for regex ‘openjdk*’
Note, selecting ‘uwsgi-plugin-jwsgi-openjdk-7’ for regex ‘o
enjdk*’
Note, selecting ‘openjdk-6-jdk’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-jre-headless’ for regex 'openjdk
Note, selecting ‘openjdk-7-jre-zero’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-jre-jamvm’ for regex ‘openjdk*’
Note, selecting ‘openjdk-7-jdk-headless’ for regex 'openjdk
Note, selecting ‘openjdk-7-jdk’ for regex ‘openjdk*’
Note, selecting ‘openjdk-6-jre’ for regex ‘openjdk*’
Note, selecting ‘openjdk-7-dbg’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-jdk’ for regex ‘openjdk*’
Note, selecting ‘openjdk-8-jdk-headless’ for regex 'openjdk
Note, selecting ‘openjdk-8-source’ for regex ‘openjdk*’
Package ‘openjdk-6-jdk’ is not installed, so not removed
Note, selecting ‘openjdk-7-jdk’ instead of ‘openjdk-7-jdk-h
adless’
Note, selecting ‘openjdk-7-jre-headless’ instead of ‘openjd
-7-jre-zero’
Note, selecting ‘openjdk-8-jre-headless’ instead of ‘openjd
-8-jre-zero’
Package ‘openjdk-jre’ is not installed, so not removed
Note, selecting ‘oracle-java8-installer’ instead of ‘openjd
-8-jdk-headless’
Package ‘openjdk-7-dbg’ is not installed, so not removed
Package ‘openjdk-7-demo’ is not installed, so not removed
Package ‘openjdk-7-doc’ is not installed, so not removed
Package ‘openjdk-7-jdk’ is not installed, so not removed
Package ‘openjdk-7-jre’ is not installed, so not removed
Package ‘openjdk-7-jre-headless’ is not installed, so not r
moved
Package ‘openjdk-7-jre-lib’ is not installed, so not remove
Package ‘openjdk-7-source’ is not installed, so not removed
Package ‘openjdk-8-dbg’ is not installed, so not removed
Package ‘openjdk-8-demo’ is not installed, so not removed
Package ‘openjdk-8-doc’ is not installed, so not removed
Package ‘openjdk-8-jdk’ is not installed, so not removed
Package ‘openjdk-8-jre’ is not installed, so not removed
Package ‘openjdk-8-jre-headless’ is not installed, so not r
moved
Package ‘openjdk-8-jre-jamvm’ is not installed, so not remo
ed
Package ‘openjdk-8-source’ is not installed, so not removed
Package ‘uwsgi-plugin-jvm-openjdk-7’ is not installed, so n
t removed
Package ‘uwsgi-plugin-jwsgi-openjdk-7’ is not installed, so
not removed
0 upgraded, 0 newly installed, 0 to remove and 19 not upgra
ed.
