Just noticed that SSL certificate at myopenhab.org is expired today.
Seems ok via Chrome:
No, not here. Something is wrong with the start en end date.
I assume not all instances have been renewed?
+1
Certificate has definitely expired as of Saturday, 1 June 2019 at 11:59:04 Australian Eastern Standard Time (about 5 hours ago). My Alexa V3 test skill is decidedly unhappy!
Getting a “504 Gateway Time-out” when connecting to Dashboard, and Alexa is not working again, restarting the cloud connector did not help, in my openhab the status is “online”
Hope @digitaldan has some time to look at it!
Just to note it: The both domains seems to use different certificates.
https://www.myopenhab.org - VALID
https://myopenhab.org - EXPIRED
Sorry for this, we have an issue with our load balancers where one renewed its certificate correctly , but the other did not. The default letsencrypt renew process we had setup for a single load balancer is not going to work reliably now that we have more than one load balancer. I am looking at changing that now to use a different auto renew process that will work for our setup.
In the mean time i manually renewed the affected load balancer a few hours ago, so we should be ok for a while.
Thanks Dan. Much appreciated.
Thanks. Good Job.
It’s expired again as of Sun,2nd August 2020.
Its renewed now, checking why our cron job is not doing this automatically.
Thank you
