The bridge shows as ‘Offline’ in the UI (after the issue is triggered), and when I disable it and then re-enable it, it stays stuck on ‘initializing’. And the last entry in the log file stays as…
‘mysensors:bridge-ser:9e527ea8ae’ changed from UNINITIALIZED (DISABLED) to INITIALIZING.
For testing, I created a rule that plays a sound when the status of the gateway changes, and didn’t realise its going off and online randomly, until eventually it goes off until a reboot.
The the first entry in events.log that indicates a problem is :
Thing ‘mysensors:temperature:9e527ea8ae:temperature_1_5’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
Then there is a similar entry corresponding to each mysensors childID.
However, after these entries, the bridge seems to re-connect and the sound plays to confirm this.
In openhab.log i get the following entries repeatedly,…
2021-03-25 22:56:10.791 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
java.text.ParseException: class java.text.ParseException : Message length is not > 4
at org.openhab.binding.mysensors.internal.protocol.message.MySensorsMessage.parse(MySensorsMessage.java:346) ~[bundleFile:?]
at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection$MySensorsReader.run(MySensorsAbstractConnection.java:342) [bundleFile:?]
but occasionally it also has
2021-03-25 22:49:15.776 [INFO ] [col.serial.MySensorsSerialConnection] - Connection request disconnection…
2021-03-25 22:49:15.776 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
2021-03-25 22:49:15.777 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
2021-03-25 22:49:19.114 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended…
2021-03-25 22:49:19.134 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
2021-03-25 22:49:20.351 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
2021-03-25 22:49:20.363 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
Im not sure what to do next, can i increase the log levels?
update:
i turned a node off (which was sending frequent updates) and noticed that the bridge wasn’t disconnecting as often.
I left a single node on, which sends a message each time a button is pressed. If i press the button too quickly then the bridge disconnects and re-connects; (however I’ve not had a single instance with the message “usb 2-3: failed to send control message: -110”)
If i don’t press a button, the bridge stays online. That is until the node sends its 5minute temperature update - and then i the bridge is disconnected again.
The issue seems to be compounded with the frequency of messages: low frequency avoids the Linux error “usb 2-3: failed to send control message: -110”, however even a single update form a node causes the bridge to disconnect briefly
