Hi All,
I’m a newbie in the IOT and have just setup my first Mysensors device (Door switch). I have tested it with Domoticz, but I want to try OpenHab as well.
I have a MySensors Ethernet Gateway setup on a Raspberry Pi and on the same Pi I have Domoticz and OpenHab2 installed. None of the two is setup to run from start-up.
Can I connect the Ethernet Gateway to OpenHab2 or do I have to change the gateway to a MQTT gateway?
Regards
