IonutS
(Ionut)
November 5, 2018, 7:47am
1
Platform information:
Hardware: Raspberry Pi 1 Model B
openHAB version: openHAB 2.3.0-1
Recently I installed the elelabs zigbee shield on top of a Raspberry Pi board and everything works fine.
However, since I need to work with MQTT as well, I would like to install a Gateway on the same Raspberry Pi.
According to this tutorial , I need to install an extra Arduino module, besides the elelabs shield.
Do you know if this is possible?
Thank you !
vzorglub
(Vincent Regaud)
November 5, 2018, 7:53am
2
If your are going to use MySensors I would recommend that you have a separate gateway:
Or:
IonutS
(Ionut)
November 5, 2018, 12:14pm
3
Thank you for the advice. May I ask why shouldn’t I go with the option that I suggested in my first post?
vzorglub
(Vincent Regaud)
November 5, 2018, 12:31pm
4
I don’t know if the shield you have already will be compatible with the radion directly on the PI.
Also it is better not to have all your eggs in the same basket
