I have tried searching the forum for my particular problem, but haven’t found anything which can help.
My openHAB2 on Raspberry Pi 3 is connected to DIY sensors and actuators (relay, reed switch, and PIR sensor) using mysensors serial gateway. I started having this problem after migration to openHAB2 (offline apt-get installation) from openHAB1.8
Here is my problem : During openHAB2 startup, after loading models, the following error occured and opanHAB2 can’t seem to communicate with mysensors node.
2016-07-22 05:42:43.114 [ERROR] [.script.engine.ScriptExecutionThread] - Error during the execution of rule ‘Arduino sends to Openhab’: cannot invoke method public java.lang.Object java.util.HashMap.get(java.lang.Object) on null
However, this error not appearing 100% of the time, but only roughly 95% of the system startup experienced this error. Dummy edit to rules file fixed it, and openHAB2 started working as expected again. Same items, sitemap, and rules were not having this issue on openHAB1.8
My guess fix to this problem:
- Rules file were not loaded last. When i check the openhab log, during startup models were loaded in the following order : sitemap, rules, items. I have tried searching the forum on how to change the order on openHAB2 and checked around my openHAB2 installation folder, but can’t seem to find it.
- For whatever reason this error appears, openHAB2 should work fine if i configure my rules to be refreshed when such error occured. However, i have little to no idea how this can be achieved in openhab.
Can anyone help me on how to fix this problem?
I have two separate rules files, first one consists of automation i run around the house, the other handles openHAB2 communication with mysensors node. Here is my rule for the later one:
import org.openhab.core.persistence.*
import java.util.*
import org.eclipse.xtext.xbase.lib.*
import org.openhab.core.items.*
import org.joda.time.*
import org.openhab.core.library.types.*
import org.openhab.model.script.actions.*
import java.util.HashMap
import java.util.LinkedHashMap
//Variable for wireless receiver
var String ArduinoUpdate = ""
var String sketchName = ""
var int V_TEMP = 0
var int V_HUM = 1
var int V_LIGHT = 2
var int V_DIMMER = 3
var int V_PRESSURE = 4
var int V_FORECAST = 5
var int V_RAIN = 6
var int V_RAINRATE = 7
var int V_WIND = 8
var int V_GUST = 9
var int V_DIRECTION = 10
var int V_UV = 11
var int V_WEIGHT = 12
var int V_DISTANCE = 13
var int V_IMPEDANCE = 14
var int V_ARMED = 15
var int V_TRIPPED = 16
var int V_WATT = 17
var int V_KWH = 18
var int V_SCENE_ON = 19
var int V_SCENE_OFF = 20
var int V_HEATER = 21
var int V_HEATER_SW = 22
var int V_LIGHT_LEVEL = 23
var int V_VAR1 = 24
var int V_VAR2 = 25
var int V_VAR3 = 26
var int V_VAR4 = 27
var int V_VAR5 = 28
var int V_UP = 29
var int V_DOWN = 30
var int V_STOP = 31
var int V_IR_SEND = 32
var int V_IR_RECEIVE = 33
var int V_FLOW = 34
var int V_VOLUME = 35
var int V_LOCK_STATUS = 36
var int V_DUST_LEVEL = 37
var int V_VOLTAGE = 38
var int V_CURRENT = 39
var int msgPresentation = 0
var int msgSet = 1
var int msgReq = 2
var int msgInternal = 3
var int msgStream = 4
var int alarmArmor = 1
// Internal Commands
var int I_BATTERY_LEVEL = 0
var int I_TIME = 1
var int I_VERSION = 2
var int I_ID_REQUEST = 3
var int I_ID_RESPONSE = 4
var int I_INCLUSION_MODE = 5
var int I_CONFIG = 6
var int I_FIND_PARENT = 7
var int I_FIND_PARENT_RESPONSE = 8
var int I_LOG_MESSAGE = 9
var int I_CHILDREN = 10
var int I_SKETCH_NAME = 11
var int I_SKETCH_VERSION = 12
var int I_REBOOT = 13
var int I_GATEWAY_READY = 14
// Mappings of each house items to its "node_id;child_id;" format
// This mappings is necessary to translate difference in items' name format for openhab and mysensor nodes
var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
"102;1;" -> "GF_Bedroom_MainRoom_1",
"GF_Bedroom_MainRoom_1" -> "102;1;",
"102;2;" -> "GF_Bedroom_MainRoom_2",
"GF_Bedroom_MainRoom_2" -> "102;2;",
"102;3;" -> "GF_Bedroom_Main_WC",
"GF_Bedroom_Main_WC" -> "102;3;",
"102;4;" -> "GF_Dining_Corridor_1",
"GF_Dining_Corridor_1" -> "102;4;",
"102;6;" -> "GF_Bedroom_WC_Mot",
"GF_Bedroom_WC_Mot" -> "102;6;",
"103;1;" -> "GF_Living_1",
"GF_Living_1" -> "103;1;",
"103;2;" -> "GF_Living_2",
"GF_Living_2" -> "103;2;",
"103;3;" -> "GF_Living_3",
"GF_Living_3" -> "103;3;",
"103;5;" -> "GF_Living_4",
"GF_Living_4" -> "103;5;",
"103;4;" -> "GF_Outdoor_Light_Front",
"GF_Outdoor_Light_Front" -> "103;4;",
"103;6;" -> "GF_Dining_Cor_Mot",
"GF_Dining_Cor_Mot" -> "103;6;",
"103;7;" -> "GF_Living_Sofa_Mot",
"GF_Living_Sofa_Mot" -> "103;7;",
"104;3;" -> "GF_Dining_2",
"GF_Dining_2" -> "104;3;",
"104;1;" -> "GF_Kitchen_1",
"GF_Kitchen_1" -> "104;1;",
"104;2;" -> "GF_Outdoor_Light_Back",
"GF_Outdoor_Light_Back" -> "104;2;",
"104;5;" -> "GF_Dining_2_Mot",
"GF_Dining_2_Mot" -> "104;5;",
"104;4;" -> "GF_Kitchen_1_Mot",
"GF_Kitchen_1_Mot" -> "104;4;",
"105;4;" -> "GF_Dining_1_Mot",
"GF_Dining_1_Mot" -> "105;4;",
"201;3;" -> "Indihome_Power",
"Indihome_Power" -> "201;3;"
// This variable is for header option for transciving message using mysensor protocol
var String MysensorHeaderOpt = "1;0;2;"
/* Receive Mysensors sensor info wirelessly
* Do not need any modification for each house architecture, but may need modification for different type of sensors
* This rule is not typical rule, but more like a binding for mysensor sensors for use in openhab
//receiving msg from mysensors gateway
rule "Arduino sends to Openhab"
Item Arduino received update
var String[] lineBuffer = Arduino.state.toString.split("\n")
for (String line : lineBuffer) {
var String[] message = line.split(";")
//logInfo("org.openhab","Received message from gateway" + message)
var Integer nodeId = new Integer(message.get(0))
var Integer childId = new Integer(message.get(1))
var Integer msgType = new Integer(message.get(2))
var Integer ack = new Integer(message.get(3))
var Integer subType = new Integer(message.get(4))
var String msg = message.get(5)
if(msgType == 1 ){
if (subType == V_TEMP){
postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), msg)
println ("Temp item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " temp: " + msg )
if (subType == V_HUM){
println ("Hum item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " hum: " + msg )
if (subType == V_LIGHT_LEVEL){
println ("Light item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " light: " + msg )
if (subType == V_VOLTAGE){
println ("Voltage item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " voltage: " + msg )
if (subType == V_LOCK_STATUS){
var String lockstatus="OPEN"
if (msg=="1"){
lockstatus="CLOSED"
postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), lockstatus)
println ("Door/Window item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Status: " + lockstatus )
if (subType == V_TRIPPED){
var String tripped="CLOSED"
if (msg=="1"){
tripped="OPEN"
postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), tripped)
println ("Button/Contact item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Status: " + tripped )
if (subType == V_LIGHT){
var String light="OFF"
if (msg=="1"){
light="ON"
postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), light)
println ("Light item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Light: " + light )
// Internal Command
if(msgType == 3){
if(subType == I_SKETCH_NAME){
println("Sketch name: " + msg )
sketchName=msg
if(subType == I_SKETCH_VERSION){
println("Sketch version: " + msg )
postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), sketchName+" " +msg )
sketchName=""
/* Send info wirelessly to each mysensor actuator nodes
* Need modifications for each house items. Just copy paste one block of rule, and change item name correspondingly
* This rule is not typical rule, but more like a binding for mysensor actuators for use in openhab
* This rule block only design to work with relays. Other type of actuators may need modification
rule "Send Arduino Command to Actuator"
Item GF_Outdoor_Light_Front changed
var String state="0"
if (GF_Outdoor_Light_Front.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Outdoor_Light_Front" ) + MysensorHeaderOpt + state + "\n")
Item GF_Living_1 changed
if (GF_Living_1.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Living_1" ) + MysensorHeaderOpt + state + "\n")
Item GF_Living_2 changed
if (GF_Living_2.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Living_2" ) + MysensorHeaderOpt + state + "\n")
Item GF_Living_3 changed
if (GF_Living_3.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Living_3" ) + MysensorHeaderOpt + state + "\n")
Item GF_Living_4 changed
if (GF_Living_4.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Living_4" ) + MysensorHeaderOpt + state + "\n")
Item GF_Bedroom_MainRoom_1 changed
if (GF_Bedroom_MainRoom_1.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Bedroom_MainRoom_1" ) + MysensorHeaderOpt + state + "\n")
Item GF_Bedroom_MainRoom_2 changed
if (GF_Bedroom_MainRoom_2.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Bedroom_MainRoom_2" ) + MysensorHeaderOpt + state + "\n")
Item GF_Bedroom_Main_WC changed
if (GF_Bedroom_Main_WC.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Bedroom_Main_WC" ) + MysensorHeaderOpt + state + "\n")
Item GF_Dining_Corridor_1 changed
if (GF_Dining_Corridor_1.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Dining_Corridor_1" ) + MysensorHeaderOpt + state + "\n")
Item GF_Dining_2 changed
if (GF_Dining_2.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Dining_2" ) + MysensorHeaderOpt + state + "\n")
Item GF_Kitchen_1 changed
if (GF_Kitchen_1.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Kitchen_1" ) + MysensorHeaderOpt + state + "\n")
Item GF_Outdoor_Light_Back changed
if (GF_Outdoor_Light_Back.state == ON){
state = "1"
sendCommand(Arduino, sensorToItemsMap.get( "GF_Outdoor_Light_Back" ) + MysensorHeaderOpt + state + "\n")
Item Indihome_Power received command
//var String state="1"
sendCommand(Arduino, sensorToItemsMap.get( "Indihome_Power" ) + MysensorHeaderOpt + "1" + "\n")
