2018-11-26 14:53:17.796 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
and
2018-11-26 14:54:33.941 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item 'Azimuth' in database with statement 'INSERT INTO Item4 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': No operations allowed after connection closed.
pid=org.openhab.mysql
# the database url like 'jdbc:mysql://<host>:<port>/<database>' (without quotes)
url=jdbc:mysql://localhost:3306/OpenHAB
# the database user
user=openhab
# the database password
password=openhab
# the reconnection counter
#reconnectCnt=
# the connection timeout (in seconds)
#waitTimeout=
# Use MySQL Server time to store item values (=false) or use openHAB Server time (=true).
# For new installations, its recommend to set "localtime=true".
# (optional, defaults to false)
#localtime=true
Okay, I think that may have fixed it, I’m getting some different errors now, but not as bad?
018-11-26 15:09:46.418 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not create table for item 'TimePeriodOfDay' with statement 'CREATE TABLE Item37 (Time DATETIME, Value VARCHAR(20000), PRIMARY KEY(Time));': Column length too big for column 'Value' (max = 16383); use BLOB or TEXT instead
2018-11-26 15:09:46.421 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Item 'TimePeriodOfDay' was not added to the table - removing index
2018-11-26 15:09:46.431 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item 'TimePeriodOfDay' in database with statement 'INSERT INTO Item37 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': Table 'OpenHAB.Item37' doesn't exist
Can you try to migrate to JDBC persistence (using MySQL as the DB)
Still trying to find out why this command doesn’t work:
It tries to create a table with 3 columns and the 2nd column should have a VARCHAR type and a length of 20k characters… but your MySQL server complaints that the VARCHAR type cannot have more than 16383 characters…
I would drop the DB… from my understanding, it is empty… correct?
stop OH2, drop DB, clean old mqtt persistence config files, fix jdbc config files, start OH2
