Should this be loading:
2018-11-26 17:25:39.786 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
if you are not using rrd4j persistence: then no
uninstall the addon and remove the persistence/rrd4j.persist and services/rrd4j.cfg files
Okay, I removed rrd4j, and restarted the service and still have the following error:
2018-11-26 17:38:05.119 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2018-11-26 17:38:05.128 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
Hereās my config:
############################ JDBC Persistence Service ##################################
# I N S T A L L J D B C P E R S I S T E N C E S E R V I C E
# https://github.com/openhab/openhab/wiki/JDBC-Persistence
# Tested databases/url-prefix: jdbc:derby, jdbc:h2, jdbc:hsqldb, jdbc:mariadb, jdbc:mysql, jdbc:postgresql, jdbc:sqlite
# derby, h2, hsqldb, sqlite can be embedded,
# If no database is available it will be created, for example the url 'jdbc:h2:./testH2' creates a new DB in OpenHab Folder.
# Create new database, for example on a MySQL-Server use:
# CREATE DATABASE 'yourDB' CHARACTER SET utf8 COLLATE utf8_general_ci;
# D A T A B A S E C O N F I G
# Some URL-Examples, 'service' identifies and activates internally the correct jdbc driver.
# required database url like 'jdbc:<service>:<host>[:<port>;<attributes>]'
# url=jdbc:derby:./testDerby;create=true
# url=jdbc:h2:./testH2
# url=jdbc:hsqldb:./testHsqlDb
# url=jdbc:mariadb://192.168.0.1:3306/testMariadb
# url=jdbc:mysql://192.168.0.1:3306/testMysql
# url=jdbc:postgresql://192.168.0.1:5432/testPostgresql
# url=jdbc:sqlite:./testSqlite.db
# url=
url=jdbc:mysql://localhost:3306/OpenHAB
# required database user
user=openhab
# required database password
password=openhab
# E R R O R H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
#errReconnectThreshold=
# I T E M O P E R A T I O N S
# optional tweaking SQL datatypes
# see: https://mybatis.github.io/mybatis-3/apidocs/reference/org/apache/ibatis/type/JdbcType.html
# see: http://www.h2database.com/html/datatypes.html
# see: http://www.postgresql.org/docs/9.3/static/datatype.html
# defaults:
#sqltype.CALL = VARCHAR(200)
#sqltype.COLOR = VARCHAR(70)
#sqltype.CONTACT = VARCHAR(6)
#sqltype.DATETIME = DATETIME
#sqltype.DIMMER = TINYINT
#sqltype.LOCATION = VARCHAR(30)
#sqltype.NUMBER = DOUBLE
#sqltype.ROLLERSHUTTER = TINYINT
#sqltype.STRING = VARCHAR(65500)
#sqltype.SWITCH = VARCHAR(6)
# For Itemtype "Number" default decimal digit count (optional, default: 3)
#numberDecimalcount=
# T A B L E O P E R A T I O N S
# Tablename Prefix String (optional, default: "item")
# for Migration from MYSQL-Bundle set to 'Item'.
#tableNamePrefix=Item
# Tablename Prefix generation, using Item real names or "item" (optional, default: false -> "item")
# If true, 'tableNamePrefix' is ignored.
#tableUseRealItemNames=
# Tablename Suffix length (optional, default: 4 -> 0001-9999)
# for Migration from MYSQL-Bundle set to 0.
#tableIdDigitCount=
# Rename existing Tables using tableUseRealItemNames and tableIdDigitCount (optional, default: false)
# USE WITH CARE! Deactivate after Renaming is done!
#rebuildTableNames=true
# D A T A B A S E C O N N E C T I O N S
# Some embeded Databases can handle only one Connection (optional, default: configured per database in packet org.openhab.persistence.jdbc.db.* )
# see: https://github.com/brettwooldridge/HikariCP/issues/256
# jdbc.maximumPoolSize = 1
# jdbc.minimumIdle = 1
# T I M E K E E P I N G
# (optional, default: false)
#enableLogTime=true
something is wrong with your system
installing the persistence addon should have deployed the necessary files (which include the required drivers)ā¦
the driver should have been pulled it from here: http://mvnrepository.com/artifact/org.mariadb.jdbc/mariadb-java-client
I donāt know what to tell youā¦
does your OH2 system have proper internet access?
Yes, as I use the remote openhab connection.
okā¦ last effort:
systemctl stop openhab2
cd /usr/share/openhab2/addons/
wget "https://downloads.mariadb.com/Connectors/java/connector-java-2.3.0/mariadb-java-client-2.3.0.jar"
systemctl start openhab2
Iām trying paperUI one more timeā¦
Which one should I try?
JDBC Persistence MariaDB
JDBC Persistence MySQL
start clean with JDBC:MariaDB
if the JDBC::openConnection: no driver available!
is still there: download the jar that I linked above to your addons directory
Well I downloaded the jar and I still have the erorr?
2018-11-26 18:52:09.854 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2018-11-26 18:52:09.860 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2018-11-26 18:52:09.866 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: No connection to database. Cannot persist item 'ntp_ntp_local_string (Type=StringItem, State=2018-11-26 18:52:09 CST)'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
Something new?
2018-11-26 19:15:51.584 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
