Hello
I properly configured (i can see entries in the mysql openhab db using phpmyadmin) the binding
I can see in items details persistence info in habmin that the persistnce strategy is properly set.
But I cannot see any item in the item list in persistence tab.
I have seen the items there just once and then not anymore.
I can see other persistece items (rr4j, sense).
As an additional note items are not visible also in the graphic blocly rule editor (i.e. in the item dropdown).
I was reading in the forum/issues that this could also be a symptom of something wrong in mysql config.
[quote=“Nicola_Reina, post:1, topic:4807, full:true”]
I can see other persistece items (rr4j, sense).[/quote]
Did you notice the little tab on the lower right hand side of the browser windows? You can switch between the different persistence services you have set up.
sure I did.
If I switch to the other persitences i mentionned items list gets populated.
not for mysql selection.
on the other hand I can see in item properties :mysql:everychange and restoreonstartup (the properties I set in the strategy persistence file)
Did you get this sorted out?
I have the same problem as you, and cant figure out why items are missing in mysql list in habmini, db is populated whit data but items are missing in habmin
