I’m running OH2.2 via a Docker container on Linux (FC24).
I recently configured persistence using MySQL, and noticed that some of my Items are not being persisted on change.
Here’s my mysql.persist:
// persistence strategies have a name and a definition and are referred to in the “Items” section
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every5Minutes : "0 */5 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
* Each line in this section defines for which item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* item (excl. the group item itself).
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyChange, everyDay, restoreOnStartup
// additionally, persist all temperature and weather values every hour
// gTemperatur* : strategy = every5Minutes, restoreOnStartup
mysql.service:
# the database url like ‘jdbc:mysql://:/’ (without quotes)
url=jdbc:mysql://redacted:3306/openhab
# the database user
user=openhab
# the database password
password=//redacted//
# the reconnection counter
#reconnectCnt=
# the connection timeout (in seconds)
#waitTimeout=
# Use MySQL Server time to store item values (=false) or use openHAB Server time (=true).
# For new installations, its recommend to set "localtime=true".
# (optional, defaults to false)
localtime=true
A sample Item:
Number Outdoor_Temp "Outdoor Temp [%.0f]" <temperature> (Outdoor, Temperature, Outdoor_TempChart) {mqtt="<[mqtt87:/env/temp/garden:state:JS(mqtt_var.js)]"}
From MySQL, I see the valie was persisted once when I enabled Persistence, and a second time at midnight (per the everyDay rule applied to all items):
mysql> select * from Items where ItemName="Outdoor_Temp";
| ItemId | ItemName |
| 18 | Outdoor_Temp |
1 row in set (0.00 sec)
mysql> select * from Item18;
| Time | Value |
| 2018-02-16 22:01:35 | 34 |
| 2018-02-17 00:00:01 | 32 |
2 rows in set (0.00 sec)
However, there were numerous changes reported that were never persisted:
$ grep Outdoor_Temp /opt/openhab2/userdata/logs/events.log
2018-02-16 22:01:34.747 [vent.ItemStateChangedEvent] - Outdoor_Temp changed from 35 to 34
2018-02-16 22:17:31.160 [ome.event.ItemUpdatedEvent] - Item 'Outdoor_Temp' has been updated.
2018-02-16 22:17:34.774 [vent.ItemStateChangedEvent] - Outdoor_Temp changed from NULL to 34
2018-02-16 22:23:22.692 [ome.event.ItemUpdatedEvent] - Item 'Outdoor_Temp' has been updated.
2018-02-16 22:23:34.755 [vent.ItemStateChangedEvent] - Outdoor_Temp changed from NULL to 34
2018-02-16 22:34:34.787 [vent.ItemStateChangedEvent] - Outdoor_Temp changed from 34 to 33
2018-02-16 22:35:34.783 [vent.ItemStateChangedEvent] - Outdoor_Temp changed from 33 to 34
2018-02-16 22:36:34.765 [vent.ItemStateChangedEvent] - Outdoor_Temp changed from 34 to 33
2018-02-16 23:23:34.946 [vent.ItemStateChangedEvent] - Outdoor_Temp changed from 33 to 32
(this continues through the current time, 2018-02-17 19:20:35.320).
The UI shows the value noted in events.log, but charts only reflect what we see in MySql (as you’d expect).
Does the MQTT binding apply a different type of change that’s not noted by the everyChange strategy?
I’m seeing this with multiple items. I’m not 100% sure, but the pattern suggests it may be related to the Number type – I have Dimmers and Swtiches that are also updated via MQTT, and they seem to be working as expected (although not interesting to chart…)
I also have rules that trigger on these Items (via Item xxx received update) that are working correctly.
Appreciate any hints. I’ve read quite a few persistence-related posts, but haven’t found any that touched on this issue.
