I have recently started using mysql persistence and at first it works fine. But then after a day I get mysql errors. And because of this my automation stops working (cant’s switch on lights anymore, as rules crash on:
if ( !KamerScene.changedSince(now.minusSeconds(1))) return false
Restarting openhab solves the problems, happened twice now…What can I do to solve this?
This is in the log…
2016-02-18 17:22:52.653 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Connection is not valid! 2016-02-18 17:22:52.653 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Connection is not valid! 2016-02-18 17:22:52.702 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Could not store item 'KamerScene' in database with statement 'INSERT INTO Item8 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': No operations allowed after connection closed. 2016-02-18 17:22:52.732 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Connection is not valid! 2016-02-18 17:22:52.732 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Connection is not valid! 2016-02-18 17:22:52.732 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Error running querying : 2016-02-18 17:22:52.794 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Kamer scene' java.lang.NullPointerException: null at org.openhab.core.persistence.extensions.PersistenceExtensions.changedSince(PersistenceExtensions.java:164) ~[na:na] at org.openhab.core.persistence.extensions.PersistenceExtensions.changedSince(PersistenceExtensions.java:147) ~[na:na] at sun.reflect.GeneratedMethodAccessor68.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71] at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na] at sun.reflect.GeneratedMethodAccessor52.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71] at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:549) ~[na:na] at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71] at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:751) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na] at sun.reflect.GeneratedMethodAccessor52.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71] at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na] at sun.reflect.GeneratedMethodAccessor50.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71] at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:327) ~[na:na] at sun.reflect.GeneratedMethodAccessor64.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71] at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na] at sun.reflect.GeneratedMethodAccessor56.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71] at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na] at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na] at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na] 2016-02-18 17:22:57.279 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Connection is not valid!
