i have configured mySQL and at some point it has created a table “items” with nothing inside. Now it just says:
2016-08-14 22:50:24.991 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - Bundle Considered for SPI providers: org.openhab.persistence.mysql
2016-08-14 22:50:24.991 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - No 'SPI-Provider' Manifest header. Skipping bundle: org.openhab.persistence.mysql
when i restart the service. Here my config:
############################ mySQL Persistence Service ##################################
mysql:url=jdbc:mysql://127.0.0.1:3306/openhab
mysql:user=root
mysql:password=blabla
mysql:reconnectCnt=10
mysql:waitTimeout=30
I am not sure if that helps, but how did you configure your mySQL Persistence ?
In your openHAB/conf/services folder, you should have a file called mysql.cfg which includes your quoted config.
If so, you need to remove the leading mysql: from each line, as this is not needed in individual config files.
Furthermore, did you configure your persistence strategy in openHAB/conf/persistence/mysql.persist ?
that was the content of the conf/services/mysql.cfg file and even without the leading “mysql:” there is no difference. My conf/persistence/mysql.persist looks like this:
# the database url like 'jdbc:mysql://<host>:<port>/<database>'
# the database user
user=root
# the database password
password=blabla
# the reconnection counter
reconnectCnt=10
# the connection timeout (in seconds)
waitTimeout=30
and the logs after restart are (with little bit more detail):
2016-08-15 13:41:10.867 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2016-08-15 13:41:15.659 [DEBUG] [org.openhab.persistence.mysql ] - BundleEvent STARTING - org.openhab.persistence.mysql
2016-08-15 13:41:15.660 [DEBUG] [nal.MysqlPersistenceServiceActivator] - mySQL persistence bundle has been started.
2016-08-15 13:41:15.687 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Attempting to connect to database jdbc:mysql://127.0.0.1:3306/openhab
2016-08-15 13:41:16.135 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Connected to database jdbc:mysql://127.0.0.1:3306/openhab
2016-08-15 13:41:16.139 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Setting wait_timeout to 30 seconds.
2016-08-15 13:41:16.140 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL configuration complete.
2016-08-15 13:41:16.142 [DEBUG] [org.openhab.persistence.mysql ] - ServiceEvent REGISTERED - {org.openhab.core.persistence.PersistenceService}={service.pid=org.openhab.mysql, waitTimeout=30, user=root, url=jdbc:mysql://127.0.0.1:3306/openhab, password=xxxxxxxx, reconnectCnt=10, component.name=org.openhab.persistence.mysql, component.id=184, service.id=335, service.bundleid=197, service.scope=bundle} - org.openhab.persistence.mysql
2016-08-15 13:41:16.142 [DEBUG] [org.openhab.persistence.mysql ] - BundleEvent STARTED - org.openhab.persistence.mysql
2016-08-15 13:41:16.142 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - Bundle Considered for SPI providers: org.openhab.persistence.mysql
2016-08-15 13:41:16.142 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - No 'SPI-Provider' Manifest header. Skipping bundle: org.openhab.persistence.mysql```
and still not a single entry in the table "items"
Jens
