Using the MySQL persistence, isn’t it possible to save the time as a Long instead of that string like (“yyyy-mm-dd hh:MM:ss”)?
One possible approach is to query the MySQL database using the UNIX_TIMESTAMP(date)
function, so you don’t change how item states are persisted, only the format in which you retrieve them:
select UNIX_TIMESTAMP(`Time`),`Value` from Item20;
Thanks, for that hint!
I guess that will speed up the creating of my chart (in an android app) a lot.
