MyUplink binding?
The binding already uses all datapoints which are exposedby the API. Therefore I cannot add anything which is not supported. The “old” F and VVM models seem to have only a very limited set of datapoints compared to newer models.
This is because there is one line of code missing in my binding. I will add it. :smiley:
On the other hand I am working on a even more generic way to detect such enum/status channels.
Ok thanks for confirming what I suspected :face_with_raised_eyebrow:, the data is there, so not supporting these datapoints is a choice from Nibe. I will open a support ticket towards Nibe and see what happens.
Thanks for your answers and keep up the good work :flexed_biceps:t2:
Hello, I placed the file “org.openhab.binding.myuplink-4.2.0-SNAPSHOT.jar” into the map /usr/share/openhab/addons and changed ownership to “openhab” (instead of “openhabian”). After sudo reboot I have errors in the log:
What could it be?
2024-05-31 16:09:06.772 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.myuplink [238]
Unresolved requirement: Import-Package: com.google.gson; version=“[2.10.0,3.0.0)”
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
2024-05-31 16:09:06.957 [WARN ] [ty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@2c2076[provider=null,keyStore=null,trustStore=null]
2024-05-31 16:09:06.959 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@2c2076[provider=null,keyStore=null,trustStore=null]
2024-05-31 16:09:08.001 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = d6…f6, base URL = http://localhost:8080)
2024-05-31 16:09:11.732 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2024-05-31 16:09:18.521 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2024-05-31 16:09:19.094 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.myuplink-4.2.0-SNAPSHOT.jar
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) ~[?:?]
Looks like the binding version is incompatible with the openhab version. It should work with 4.2.0.M2
Hi Alexander,
thx for your great work - i still updated to myuplink.
One Point to the writeable values:
In the API the value shoud be writeable
    "category": "SMO 40",
    "parameterId": "40940",
    "parameterName": "current value",
    "parameterUnit": "DM",
    "writable": true,
    "timestamp": "2024-05-30T10:22:31+00:00",
    "value": 98,
    "strVal": "98DM",
    "smartHomeCategories": [],
    "minValue": -30000,
    "maxValue": 30000,
    "stepValue": 100,
    "enumValues": [],
    "scaleValue": "0.1",
    "zoneId": null
By testing i get errors in the log that the channel write access not supported:
2024-05-31 18:05:55.265 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.myuplink.internal.handler.MyUplinkGenericDeviceHandler@672a04a2': channel (40940) does not support write access
java.lang.UnsupportedOperationException: channel (40940) does not support write access
	at org.openhab.binding.myuplink.internal.handler.MyUplinkThingHandler.handleCommand(MyUplinkThingHandler.java:101) ~[?:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) [bundleFile:?]
	at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
	at jdk.proxy20440.$Proxy20573.handleCommand(Unknown Source) [?:?]
	at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:95) [bundleFile:?]
	at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [bundleFile:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
That was the problem, now it works!! Thanks!!!
The latest version is no longer compatible with 4.2.0.M2 but works with the latest snapshot version.
The binding now supports any channels that have a number to text mapping (enum type). Write access is supported for Switch type channels. This is tested with my setup and works.
Write access should also be possible for those enum-type channels if it is supported by that specific channel in the API. This is untested so far.
Thanks for the update @AlexF
I upgraded to latest OH-snapshot, and added your new JAR.
When I try to add extra hot water I get this in the logs,
2024-06-02 21:08:09.084 [INFO ] [handler.MyUplinkGenericDeviceHandler] - channel '61503' does not support write access - value to set '0.5'
2024-06-02 21:08:09.085 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.myuplink.internal.handler.MyUplinkGenericDeviceHandler@2681d26': channel (61503) does not support write access
java.lang.UnsupportedOperationException: channel (61503) does not support write access
        at jdk.internal.reflect.GeneratedMethodAccessor210.invoke(Unknown Source) ~[?:?]
        at jdk.proxy2253.$Proxy2422.handleCommand(Unknown Source) [?:?]
        at jdk.internal.reflect.GeneratedMethodAccessor209.invoke(Unknown Source) ~[?:?]
Same on a few other channels i tried.. 61500 and 61517 for example.
I have also testet with the updated binding.
Number channels still doesnt work for me with the same errors in the log like MrRusch.
I only have one Switch channel (Temp. Lux) who works by switching (write access).
With use of the NibeUplink binding it was possible to see if status heating, cooling or hotwater production was active. I can’t find any channels with this info in the myUplink binding. I use this status to calculate the COP during heating, cooling or hotwater production. Is it true that this info is not available within the myUplink binding?
It depends on your model. The binding detects all datapoints that are exposed by myUplink.
For my VVM320 there is a channel named similar to “priority”. That can be used.
But for my VVM320 the heatmeters are not being updated on regular basis. In fact this only happens on startup of the VVM320 main unit. I am not sure whether this issue applies to other models as well.
One update from my end:
A new firmware for my VVM320 is available which fixes the heat meter issue and also adds a lot of additional channels (435 instead of 79). I will test this but it looks like I need to adopt the binding since there are too many channels now which are not categorized and have identical names (many are related to schedules). Currently I do not have any idea how to do this in a generic way…
Looks like the end is nigh for the old NIBE Uplink. They went from “hey your pump is not supported” to “switch now, or loose price tracking” within only a couple of months :grimacing:
I also got an update for my F750, it seems to have activated some of the things in the smart-home-categories. But still no smart-home-zones despite my system being split into two circuits (floor heating on the bottom floor and radiators upstairs which is handled as two systems on the heatpump). The only difference I see from this is that it’s present in a field smartHomeCategories for some of the parameters.
I also have a bunch of new parameters, mostly different settings it seems, but the descriptions are unfortunately not very good for many of them.
They do seem to have different parameterId, so should be able to handle it in the binding and have separate channels at least, but to make it user-friendly seems very difficult. As of now the users would likely have to manually investigate what exact parameters on the heatpump corresponds to each channel. Hopefully Nibe can update with better descriptions for the parameters, that’s the only solution i can see at the moment.
Update: If the parameters are sorted by parameterId, the ones belonging to the same schedule is at least grouped together. First is an ‘activated’ parameter for each of the schedule types, followed by start time for each day of the week (in reverse order), end times, and finally the setting for each day. The setting can be used to determine what the schedule is supposed to configure which could be used to categorize and group them. There also seems to be two schedules for each setting (which is what can be configured on my heatpump as well).
The different settings I have for the schedules are: Comfort mode (for hot water), Fan speed, heating curve offset (some with configurable heating system, some without), blocking (compressor, electric addition, both). Then there is one additional schedule that doesn’t follow this pattern, so no idea what it does.
Thanks for this binding!
Been trying it now for a week for my F1255, and most of the parameters seem to be identified and listed (suspect limitation on the cloud end for remaining ones which were available in the old API).
However, one big issue as arisen - it seems like only 10 attributes gets updated each interval. I have 30+ values I’d like to have updated, but now it just selects 10 at random and updates those, while remaining ones are never refreshed. The 10 selected remains constant until a restart, when OpenHab selects 10 new ones.
Could there be a limitation to only allow 10 values on each fetch, and then a need to split up the refresh in multiple requests?
Edit: tried via swagger, it seems possible to request many more than 10 datapoints at the same time, without any pagination. So a binding issue?
Also, it would be great if there was a field to allow for change of language for text based fields (Accept-Language header)
For me it works fine. There are more than 10 channels being updated whenever they change.
I had an issue related to the heat meters which were not being updated at all. (Only restart of the heatpump resulted in a one-time update) This was fixed by NIBE with a firmware update. But this issue could also be reproduced via swagger.
I think you’re partially correct - turned on debugging for the binding, and all parameters seem to be fetched correctly, however they’re not being updated either on the cloud side or in OpenHAB.
This the firmware is the latest available, published 20 days ago, so I’ve reported an error back to myUplink for the values that aren’t updated on the cloud side, however there seem to be some kind of error also on the local side. As an example, the room temperature 40033 has a link to an item, but the item is never updated, even with newly fetched data. This is from the log:
2024-07-23 15:40:52.686 [DEBUG] [nal.model.GenericResponseTransformer] - received channel data: {"category":"F1255-12 CU","parameterId":"40033","parameterName":"Room temp­erature (BT50)","parameterUnit":"°C","writable":false,"timestamp":"2024-07-23T12:59:39+00:00","value":24.6,"strVal":"24.6°C","smartHomeCategories":[],"minValue":null,"maxValue":null,"stepValue":1.0,"enumValues":[],"scaleValue":"0.1","zoneId":null}
2024-07-23 15:40:52.687 [DEBUG] [nal.model.GenericResponseTransformer] - mapping value '24.6' to channel 40033
For an item being updated, I get the following:
2024-07-23 15:45:54.364 [DEBUG] [nal.model.GenericResponseTransformer] - received channel data: {"category":"F1255-12 CU","parameterId":"40004","parameterName":"Current outd temp (BT1)","parameterUnit":"°C","writable":false,"timestamp":"2024-07-23T13:27:18+00:00","value":22.9,"strVal":"22.9°C","smartHomeCategories":["sh-outdoorTemp"],"minValue":null,"maxValue":null,"stepValue":1.0,"enumValues":[],"scaleValue":"0.1","zoneId":null}
2024-07-23 15:45:54.365 [DEBUG] [nal.model.GenericResponseTransformer] - mapping value '22.9' to channel 40004
2024-07-23 15:45:54.900 [DEBUG] [handler.MyUplinkGenericDeviceHandler] - Channel is to be updated: myuplink:genericDevice:[sanitized]:40004: 22.9 °C
Hi. Thanks a lot for this binding!
I have a little problem with Generic Command channel - unable to send a negative number (to Degree minutes param):
[INFO ] [nternal.command.AbstractWriteCommand] - channel ‘command’ does not allow value ‘40940:-200’ - validation rule ‘[0-9]+:[0-9,]+’
Could you please edit validation rule to accept minus sign? Thanks!
Hey @hal295, I am really curious as to how you are using the manual degreeminute setting? Are you triggering heating by some automation?
