Hi everyone,
I am working with OpenHAB for about 1 year. I was playing around with all kind of devices (Philips, Osram, IKEA, Aqara, Tasmota, Xiaomi, Homematic).
At the moment I got about 75 things connected.
My first goal was to get to know how to merge them all together to be “smart”. I am using also Node Red and InfluxDB and Grafana as well as 7 Amazon Echos.
My goal is to have all things in OH, from there I want to feed Node Red, Influx and the Echoes.
I think I have managed it to get nearly all running the way I want it.
As I was playing around a lot with the devices, so my whole setup is a little bit messed up.
So I decided to set up a brand new environment to create a solid base for my existing devices and the upcoming
So now my question:
As I have a lot of devices, what would be the a good naming convention for.
At the moment, a thing looks like this:
Group gTemperatureSensor_T1 "Temperatur-Sensor Büro" (gTemperatureSensors, gFlur_EG) {alexa="Endpoint:TemperatureSensor"}
Number T1_Temperature "Temperatur Büro [%.1f °C]" (gTemperatureSensor_T1, gTemperatureSensorsEG) ["CurrentTemperature"] {channel="deconz:temperaturesensor:0c922491:00158d000309b543010402:temperature"}
Number T1_Battery_Level "Batterieladung Büro" (gTemperatureSensor_T1, gTemperatureSensorsEG, gBatteryCharge) {channel="deconz:temperaturesensor:0c922491:00158d000309b543010402:battery_level"}
Switch T1_Battery_Warning "Batteriewarnung Büro" (gTemperatureSensor_T1, gTemperatureSensorsEG, gBatteryWarning) {channel="deconz:temperaturesensor:0c922491:00158d000309b543010402:battery_low"}
As you can see, I got the items grouped, I got several physical and logical groups. Works not that bad in OH, but also doesn’t feed that good. I got the feeling there is a better way.
It also looks terrible when importing it in the echoes as there are a lot of items with the same name. Maybe these are old ones, but they reappear when deleting ans adding again.
Maybe you can give me some tips/hints or exaples you you managed it.
Thanks in advance
Jarod
