There is an older error in the logfile, but itâs from the time when I was still playing around with the items/control.
2019-04-22 21:21:24.165 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHa ndler.handleCommand()' on 'org.openhab.binding.nanoleaf.internal.handler.NanoleafHandler@1b836fd': Unhandled command typ e
org.openhab.binding.nanoleaf.internal.NanoleafException: Unhandled command type
at org.openhab.binding.nanoleaf.internal.handler.NanoleafHandler.sendEffectCommand(NanoleafHandler.java:148) ~[? :?]
at org.openhab.binding.nanoleaf.internal.handler.NanoleafHandler.handleCommand(NanoleafHandler.java:189) ~[?:?]
at sun.reflect.GeneratedMethodAccessor39.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.j ava:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:o rg.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy138.handleCommand(Unknown Source) [212:org.openhab.binding.nanoleaf:2.5.0.201901190212]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java :75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfil e.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor38.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.cor e:0.10.0.oh240]
But I doubt that it has an effect here?
Just to be sure, I restarted the openhab service. After it was back online, I tested whether the binding works and then tried the scan again, three times. The first time nothing happened (maybe openhab still starting up?) the two other times are in the log.
Can I manually look for the IDs? I found another thread with an URL where you supposedly see them, but that just returns a blank page in my browser (yes, I changed the ip from the example).
Is this an old version of the Binding I have? It says its 2.5.0. Or do I have to do it via a file in the Editor?
If so can you please share a screenshot on what to add? Especially for the Individual Light Panels.
You can check out the binding documentation which has an example of a thing file which contains the controller/bridge definition with two (light)panels. The id is set as a configuration parameter [ id=... ] on each lightpanel thing type.
So just tried to add the jar to my 2.3.0 and see if i can make it work. It appears i cant âŠ
At first i added it via Paper UI, which lead to a controller that was usable (tested with power channel). I could not discover any panels however. The solution this thread provides is to add all things as text files.
I cant add the controller as things file properly though, the port and ip adress are always missing in paper ui (when i look at it). The thing is shown as offline.
I see the following error: â2019-07-12 23:19:11.825 [ERROR] [eaf.internal.handler.NanoleafHandler] - URI could not be parsed with path /api/v1/â The token is correct.
Sidenote: if i use the string ânanoleaf:controller:MyLightPanelsâ from the documentation i get alot exceptions in my logs, and if i use ânanoleaf:lightpanels:MyLightPanelsâ i only get the above error regarding the API call.
Is this because im on 2.3.0? Or is there any point i am missing?
I have a question regarding the Nanoleaf binding - good job by the way - itâs this:
I downloaded the binding and copied the .jar file to /usr/share/openhab2/addons which caused it to pop up in the Paper UI inbox from where I was able to activate it, it automagically detected the Canvas I had on-line and after pairing the panels activated the control in Paper UI - this is where I became confused - I could switch the panels on and off, control brightness and colour from Control but could not activate any additional functions.
I created the .map in transform, the sitemap, items and the thing and I could control all of the functions - the question is why? Does it require both the thing I created and the thing which automagically appeared or is there a way I can massage them into a single thing?
Hi Stefan, no, because I donât own a Canvas/touch device for testing. However, based on the API documentation, I started this branch which may be a good start for somebody owning a Canvas to continue testing and developing
No - not yet, but looks like a nice solution when using the Canvas as stylish switches! As mentioned by @OMR , it would be great to have this functionality integrated in the binding one day.
This is great. I can only fly blind when developing against the API documentation.
Iâve forked the current OH2 addon repo (which now contains the latest bug fixes for the binding) and created a new feature branch for the Canvas device support. You can clone it from here. After that, just go into the bundles\org.openhab.binding.nanoleaf subdirectory, and run mvn clean install -DskipTests. This should build in the target directory a JAR file you can use for testing with your devices.
After you have deployed the new JAR file to your OpenHAB (test) instance, go to the binding configuration (e.g. in PaperUI). There you will see a new configuration parameter for the âDevice Typeâ, which allows you to switch between âLight Panelsâ and âCanvasâ device.
If you want to see my initial changes made to the current version of the binding to support the Canvas device, you can use this view on GitHub.
Hope this helps to get you started, and let me know if you have any questions.
After giving up the last time, I tried it again tonight, but still ran into the same problem with auto discovery. So now, I removed everything and added all 21 panels as items by hand, using the template from the readme. Once done, I opened the site map in the basic UI and tried the controller first ⊠on/off ⊠not working. No errors in log. I tried changing the color of a single panel ⊠nothing. Only errors from missing mappings (Null, - ) in the log. I checked the .items file twice for proper IP, port and auth ⊠all good. This is the last thing in my home that I havenât integrated and Iâm quite frustrated. There are so many possibilities for using the lightpanels as status indicators/output for various processes around the home. Or for simply displaying the weather forecast âŠ
But is this being developed anymore, besides canvas? It seems the last commit to the master branch was in JanuaryâŠ
Yes, it is. I picked it up by adding the canvas and it is working fine for that and it is working well for light panels on Martinâs side. Do you mind to wait until the latest version with my addition has been made available and we then start debugging it.
I have also made the documentation a bit more elaborate how to solve some common problems which might help you.
Hey guys,
I can also only control the whole Aurora but not every single tile. Since Nanoleaf firmware updates frequently change the API i was reluctant to update in the past . I would be happy to also test once the new version is out.
Sebastian, I had the same issue as I didnât really understood how to setup the tiles (we call them lightpanels). Please follow the new instructions that I have posted above and see if the controller is discovered. Then run a second discovery which should discover the lightpanels (hence tiles). Only then try to access them. Note that accessing (general) settings at the controller may overwrite the settings on a single lightpanel.
Oh so I should check out the canvas branch? Yes, I have set it to debug already. Iâd be happy to test the new Version as well. With some luck, Iâll be able to do some testing on Wednesday.
Is there a snapshot ready for check out? The link to the new docu is not working for me (404).
I guess you mean this?
It doesnât seem much different than the previous docu, just the touch stuff is new
