Hi guys,
I just installed OH via apt-get on the latest version of Rasbian for my PI. Everything has been a breeze to setup thus far, however, I’m having problems with something simple—Upon first setting up the HUE hub, I used my android app to pair. I just wanted to do this to see if the system worked. I haven’t setup any lights via the app yet, just paired it.
So, I go to pair the HUB with openhab and I’ve done the perfunctory uncommenting of the 3 values in the openhab.cfg file:
hue:ip=10.0.0.18
hue:secret=openHABRuntime
hue:refresh=10000
However, I’m receiving the following messages when I tail -f the log file:
2016-09-26 15:34:59.948 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 72 seconds…
2016-09-26 15:35:00.963 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 71 seconds…
2016-09-26 15:35:01.635 [WARN ] [inding.hue.internal.HueBinding] - openHAB not authorized to access Hue bridge
2016-09-26 15:35:01.973 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 70 seconds…
2016-09-26 15:35:02.986 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 69 seconds…
2016-09-26 15:35:03.998 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 68 seconds…
2016-09-26 15:35:05.010 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 67 seconds…
2016-09-26 15:35:06.021 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 66 seconds…
2016-09-26 15:35:07.038 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 65 seconds…
2016-09-26 15:35:08.051 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 64 seconds…
2016-09-26 15:35:09.063 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 63 seconds…
2016-09-26 15:35:10.082 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 62 seconds…
2016-09-26 15:35:11.094 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 61 seconds…
2016-09-26 15:35:11.649 [WARN ] [inding.hue.internal.HueBinding] - openHAB not authorized to access Hue bridge
My question is this: Did I screw something up by initially pairing the HUB with my phone? I’ve turned off wi-fi on my phone and even did a factory reset of the HUB to try to re-pair, but the 3 lights on the HUB always light up as if it’s already cycled through a pair. The pair button on the HUB doesn’t even respond as the light around the button and the 3 lights below it are already lit.
I know my IP address is correct as I can see the HUB in the router gateway software UI.
What am I missing here??
FYI: I’ve seen this thread concerning HUE binding and I don’t think it addresses my problem: https://github.com/openhab/openhab/pull/4311
Thanks in advance for your assistance.
MC
