Hi Everyone,
just as side note, my production system runs oh 2.5 pretty stable for two years now and i am setting everything up from scratch as I am switching to oh 3.2. So at some point i got confused and sure enough I try to do things better and “the right way”. So in oh2.5 I have everything set up in files. Now I try to hang on to the UI witch gets frustrating some times. But so what. Now all my rules I migrated from DSL to JSScript (5.1) until I just fell over one of the articles saying that it is basically deprecated. So now I am transformig from 5.1 to JSScript 11. I do have one of my scripts done now and would appreciate if someone with experience could take a look if things are good or if something can be done better. The script in fact works. So please give me your thoughts on my solution.
if (items.getItem("V_Alarm_Internal").state == 'ON' || items.getItem('V_Alarm_External').state == 'ON'){
var pushover = actions.get("pushover", "pushover:pushover-account:xxxxxxxxx");
var exec = actions.Exec;
var time = Math.round(Date.now()/1000);
var itemName = triggeringItem.label
var picturesDirectory = "/usr/share/openhab/pictures/";
var destination = "";
var source = "";
if (items.getItem("V_Alarm_Internal").state == 'ON'){
pushover.sendPriorityMessage(itemName + " wurde geöffnet", "ACHTUNG, (STILLER) ALARM!!!", 1);
} else if (items.getItem('V_Alarm_External').state == 'ON'){
pushover.sendPriorityMessage(itemName + " wurde geöffnet", "ACHTUNG, ALARM!!!", 2);
var cameraIDList = ['id1', 'id2', 'id3', 'id4', 'id5'];
var cameraNameList = ['Ostseite', 'Haupteingang', 'Westseite', 'Terrasse', 'Garage'];
java.lang.Thread.sleep(3000);
for(var i = 0; i < cameraIDList.length; i++){
source = "http://xxxxxxxxxx:8080/xxxxxx/jpeg/xxxxxxxx/" + cameraIDList[i] + "/s.jpg";
destination = picturesDirectory + cameraNameList[i] + "." + time + ".jpg";
exec.executeCommandLine("wget", source, "-O", destination);
java.lang.Thread.sleep(500);
pushover.sendAttachmentMessage(cameraNameList[i], cameraNameList[i], destination, null);
exec.executeCommandLine("find", picturesDirectory, "-name", "*.jpg", "-type", "f", "-mtime", "+10", "-delete");
Is there a convinient way to save global constants in one script and use them in all rules? For example the IP address of my CCTV instance. I need that in multiple rules. So I would like to prefer one place to define that.
Only with JS Scripting where there is a cache Map Object that is shared across all rules.
In all other cases if you are writing in text files instead of the UI you can define “global” variables at the top of the file which is shared between all the rules in that file. In UI rules you are currently out of luck.
Ok, thank you! Worked fine with global variables in the cache. I am starting a script at system startup witch sets all the needed variables in the cache.
I hear a lot of talk about the need for ‘global variables’ in various different languages used in openHAB and always wonder why an unbound item isn’t a good solution?
i hate to ping people but Rich @rlkoshak could you answer this?
You can’t put a Timer into an Item. You can’t instantiate an Object from a library like my TimerMgr or LoopingTimer or the like in an item.
Am Item or great to hold a value, but not sufficient of you need to hold an Object like a Timer.
I do encourage the use of Items, tags, and metadata or sharing values between rules, even complicated data structures. But if you need to call a function like timer.reschedule() an Item simply can’t do the job.
Ok, I thought about that too. But I cannot find any place (in the UI) where to store additional information. If I could create some type of custom field where I could store that kind of information it would be great. I tried it with Metadata (Custom Namespace) but it didn’t work for me. For some reason my custom Metadata doesn’t appear in the Metadata list. Defining the item as String doesn’t really make it either because I cannot set a fixed value.
Not claiming that it is a perfect solution, but I use datetime items for this. Any rule can change a datetime item. I have a rule that triggers if the datetime item is changed. The rule itself just starts or reschedules a timer to the current value of the datetime item. As an extra benefit, this means that your timers will ‘survive’ a restart of openhab. Of course in that case you need some logic to make sure that the value of the datetime item is in the future.
I hope you don’t mind me writing your rule in JRuby
Things to note:
This is a fully file based rule, not GUI, so it includes the trigger and rule definition, not just the rule ‘body’
Don’t need to download the image as a file, then later on delete them (unless you want to keep the images?). Pushover lets you send the raw image (in memory)
Not using sleep. Instead we use a timer for fetching the snapshot from each camera, so the fetching runs in parallel
I haven’t tested this, so there may be some minor errors. I’d be happy to help further.
require 'openhab'
require 'net/http'
CAMERAS = {
id1: 'Ostseite',
id2: 'Haupteingang',
id3: 'Westseite',
id4: 'Terrasse',
id5: 'Garage'
rule 'Internal Alarm' do
changed V_Alarm_Internal, to: ON
triggered do |item|
pushover.sendPriorityMessage("#{item.id} wurde geöffnet", "ACHTUNG, (STILLER) ALARM!!!", 1)
rule 'External Alarm' do
changed V_Alarm_External, to: ON
triggered do |item|
pushover.sendPriorityMessage("#{item.id} wurde geöffnet", "ACHTUNG, ALARM!!!", 2)
CAMERAS.each do |id, name|
after(3.seconds) do
source = "http://xxxxxxxxxx:8080/xxxxxx/jpeg/xxxxxxxx/#{id}/s.jpg"
image = Net::HTTP.get(URI(source))
pushover.sendAttachmentMessage(name, name, image, nil)
def pushover
things['pushover:pushover-account:xxxxxxxxx']
