Flopsi
(Florian)
#1
Hello
I need help with programming a custum widget.
Here is the current code:
<div class="" ng-if="(config.top_label)">{{config.top_label}}</div>
<widget-icon iconset="config.item_icon_iconset" icon="config.item_icon" size="30"></widget-icon>
<span ng-if="(config.string1_label)">{{config.string1_label}}</span>
<span>{{itemValue(config.string1_item)}}</span>
I would like to show the status of devices in the network.
I have reached the point where the value read out from the data point is displayed.
Now I do not want to have true or false but online / offline.
How do I do it ?
Thanks for Help.
RolfV
(Rolf Vermeer)
#2
Assuming your item is a String item, you can do this:
{{ itemValue(config.string1_item) == "true" ? "online" : "offline" }}
This structure is called a ternary operator, basically an inline if-else statement.
If at some point you would have a Numer item, you can basically do the same thing:
{{ itemValue(config.number1_item) == 1 ? "online" : "offline" }}
Flopsi
(Florian)
#3
Thanks for your help. It works.
Now I have one more question.
Here is my code:
> <div style="color: rgb(255, 123, 0)">
> <div ng-if="(config.top_label)">{{config.top_label}}</div>
> <br>
> <div style="color: rgb(0, 204, 102)">
> <span>{{ itemValue(config.string1_item) == "true" ? "online" : "offline" }}</span>
> </div>
Currently the text color is green no matter if the device is online or offline.
I would like the text to be green when the device is online and red when offline.
Unfortunately, I can not program so well and try to teach myself with copy past the whole thing.
Thanks for Help
RolfV
(Rolf Vermeer)
#4
You can do the same there as for the value:
<div style="color: {{ itemValue(config.string1_item) == 'true' ? 'rgb(0, 204, 102)' : 'rgb(255, 0, 0)' }}">
Flopsi
(Florian)
#5
Her is my code:
<br>
<div style="color:{{ itemValue(config.string1_item) == 'true' ? 'rgb(050, 205, 050)' : 'rgb(178, 034, 034)'">
</div>
Where do I make a mistake. Unfortunately, it is not.
RolfV
(Rolf Vermeer)
#6
Apologies, I forgot to add the closing accolades. See my edit in the answer above.
